TPS question
Old Jan 9, 2010 | 02:06 PM
bboysyck's Avatar
TPS question
does anyone have a picture of the TPS, i need a new one, but i cant find any pictures on the internet of wat it looks like.
can someone help me out?
Old Jan 9, 2010 | 02:48 PM
otter's Avatar
EvoM Administrator
We don't have a TPS.
Old Jan 9, 2010 | 02:56 PM
bboysyck's Avatar
then wat is it that controls the throttle response?
Old Jan 9, 2010 | 04:47 PM
otter's Avatar
EvoM Administrator
Accelerator pedal position sensor. The thing behind the passenger headlight that the throttle cable goes into.
Old Jan 9, 2010 | 06:02 PM
lsalex's Avatar
bur why u need a new tps?
what is ur problem?
Old Jan 9, 2010 | 07:06 PM
hackish's Avatar
There are actually 2 TPS sensors on the car. They are part of the throttle body mechanism. There are 2 APS sensors as well. Follow the throttle cable under the hood and that's the APS. Get a friend to pump the gas with the car off, see that thing moving? Normally you will get a limp mode that says something to the effect of TPS main/sub disagrees or APS main/sub disagrees.
-Michael
Old Jan 9, 2010 | 07:37 PM
Christoforo's Avatar
If we have no TPS then what is my Scangauge II measuring when its set to TPS?
Old Jan 9, 2010 | 07:54 PM
xspsi4's Avatar
Oh wow
Old Jan 10, 2010 | 12:26 AM
bboysyck's Avatar
what is ur problem?
every time my car starts it stalls out, had someone read the computer and the code read a faulty TPS, and i did some research and tests and the conclusions were all the same, faulty TPS. so i need to replace the TPS to prevent the stall out.
Old Jan 10, 2010 | 07:29 AM
hackish's Avatar
Sounds like a good time to just get a replacement throttle body. I believe the TB is a bosch designed unit - if so I am not convinced that you can replace just the TPS. Maybe look at swapping on the larger eclipse TB.
-Michael
Old Jan 10, 2010 | 02:45 PM
lsalex's Avatar
u could try to disconect the maf sensor and all wires that join the aceleration
and try to clean them then u could try and see what happens maybe that could work
and disconnect the battery and reset the ecu or just take it out then just put it on let the key on with out the engine leave it like 10 min then start engine leave it 5 min then u could try and see if that works
Dvolution
Jan 14, 2014 03:29 PM
foxbat
Sep 24, 2013 01:20 PM
EvoIXPilot
Feb 23, 2013 12:27 PM
yellowevo82
Aug 30, 2009 02:31 PM
