Flywheel Help
Old Feb 2, 2011 | 05:00 AM
Ralliartize It's Avatar
I think there were two primary issues.
1. TOB
2. Pressure plate. It seems their HD pressure plate is just to strenuous on the stock hydraulic system, and causing premature failure.
Old Feb 2, 2011 | 03:21 PM
ralliart610's Avatar
Update
Ok, I just got off the phone with clutchmasters. I called the number on there website and now I'm really confused. The guy in the parts department told me the flywheel part number for 2006 Lancer Ralliart is FW-045-AL. I cant find anything with that part number. I think im just gonna order the one for the 4g69 eclipse.
I also called clutchflywheel.com and they said they have nothing with FW-045-AL. They told me the fadanza flywheel part number is for the ralliart, eclipse and outlander with the 4g69. But the clutchmasters one says FW-103-AL is just for the eclipse 4g69. The FW-0103-AL is for the ralliart, probe, and mazda 626 because they are all 2.4l. I tried to explain that the 06-08 eclipse had the EXACT same motor and trans, but he said i should still order FW-0103-AL because the probe and 626 have a 2.4l also. I think i'll just order the one for the 4g69 eclipse. I highly doubt the one for the probe and 626 will fit the ralliart. Just cause they are a 2.4l also doesnt mean anything. Why wouldn't the eclipse be in that catagory to?
Old Feb 2, 2011 | 04:30 PM
Don't just order. Make sure everything is 100% what you need.
Old Feb 2, 2011 | 04:37 PM
Well the eclipse one should fit. I dont see why it wouldnt. Its the same motor and trans. The part number is the same for the fidanza one.
Old Feb 2, 2011 | 05:28 PM
check club4g.org for confirmation on part number.
Old Feb 3, 2011 | 04:36 AM
turboart's Avatar
ralliart_on_LSD has the CM flywheel i pmed him asking what the part numbers were ill post when i get em
Old Feb 3, 2011 | 09:55 AM
Xenon84's Avatar
Anyone have any complaints of the fadanza? Or recommend the CM over it? I'm also replaving my utch and flywheel as doon as funds allow!
Old Feb 3, 2011 | 10:37 AM
The Fidanza flywheel will work just fine. It's the lightest of flywheels available for the RA. I think there was an issue where it wasn't fitting correctly with the stock clutch, but I can't confirm that 100%.
Old Feb 3, 2011 | 12:53 PM
I figured i would get the clutchmasters one just because i've already ordered my clutchmasters clutch. That and I've heard about problems with the fidanza one.
Old Feb 3, 2011 | 01:35 PM
Ralliart_on_LSD's Avatar
I checked my shed, I dont have the box or part number for the CM flywheel. Sorry guys. I installed that bad boy like 4-5 years. than i took it out and took a few pounds off of it 3 years ago. than six months they balanced it along with the rest of the rotation assembly. So even if you needed stock measurements i couldnt help you Sorry guys.
Should also add this. When i first did my transmission work. I got the CM flywheel and clutch. stage 1. Burnt the crap outta that clutch. So I got an ACT stage 3. i highly recommend paying the extra 30-50 dollars and get the ACT. obviously works with the CM flywheel, cuz thats my setup now. It will last longer and grab so much better. And if your going to ask "how is the stage 3 for a daily driver" I had it for 2 years before the motor blew. daily driver, and used it for a job. Heres how you fix the stage 3 clutch/daily driver problem. Man up. lol. My Ex GF could drive it. and race it pretty decent too.
Last edited by Ralliart_on_LSD; Feb 3, 2011 at 01:39 PM. Reason: flywheel. not clutch. my bad
Old Feb 3, 2011 | 02:32 PM
lancerralli06's Avatar
How were you driving with the CM clutch and fly stage 1 and with what mods?
Old Feb 3, 2011 | 03:20 PM
i had it back when I was NA. it was good for that setup. Roasted the clutch about 2 months into going turbo. but than again I beat the ***** off the car. Either or. 2 months turbo'd and it was DONE. could hit any type of boost w/out it revving to 6grand.
Old Feb 3, 2011 | 03:40 PM
Xenon84's Avatar
here is what I found on one sight for CM http://www.customcarscentral.com/cms...hi-lancer.html
lists the part # FW-0103-AL
its also listed the same at Vividracing as FW-0103-AL
Old Feb 3, 2011 | 03:43 PM
xmaster19's Avatar
Originally Posted by ralliart610
The FW-0103-AL is for the ralliart, probe, and mazda 626 because they are all 2.4l. I tried to explain that the 06-08 eclipse had the EXACT same motor and trans, but he said i should still order FW-0103-AL because the probe and 626 have a 2.4l also.I highly doubt the one for the probe and 626 will fit the ralliart. Just cause they are a 2.4l also doesnt mean anything. Why wouldn't the eclipse be in that catagory to?
Probes GT's and MX-6's had a 2.5L V6 (KL-ZE) and base model had 2.0L 4cyl (FS-DE).
Engine size DOES NOT influence directly clutch choice. It's mainly clutch diameter, torque capacity, spline count, etc...
TL;DR :
It is possible that the same clutch goes in an MX-6/PGT and in a RA...
Old Feb 3, 2011 | 06:03 PM
I think I'll just order the one for the 06 eclipse.
RA on LSD, how was fitment with the clutchmasters flywheel? Any issues like the fidanza one? Also whats your input on it, was it worth the money or not?
