Flywheel Help
Old May 18, 2011 | 04:18 PM
  #91
GearDownSon's Avatar
Originally Posted by turboart
my dad cracked the damn gear housing but got it apart. hes having the guy he was with look into taking it to a machine shop. although i really would almost rather have a a new tranny just so i know its all intact, i dont have to put it back together and because he said i need counter shaft bearings and some other 2 bearings that he isnt sure what it is (he said axel something or differential bearings). i have 2 input shaft bearings now i need 4 more and i dunno what 2 are. i havent seen the tranny since he took it and i dont have access else id look but does anyone know what he could be talking about with those bearings?
Thats why i had a tranny guy do it. Its assembled a certain way. I got it cracked about a quarter of an inch an it was hanging.
Old May 18, 2011 | 05:15 PM
  #92
CrAnSwIcK's Avatar
If you do it right, the transmission case basically falls apart, nothing should have cracked, it should come apart quite easily...hope the repair goes well. If you need any help i just had my transmission completely apart, to replace bearings and synchros, and it's back together now. shoot me a PM.
I replaced both bearings for input and output shaft, input shaft oil seal, diff bearings, cause i dropped in an LSD while i was in there, also you will need differential oil seals. If they are worn, i would recommend the input shaft seal you don't want gear oil in the clutch.
also i replied to your part number request
Old May 18, 2011 | 05:32 PM
  #93
turboart's Avatar
Yeah I checked that Thx I wish I knew what I need but i haven't been able to check it out. kinda think I need a new tranny cuz i think they jacked it up pretty bad. I cant get a straight damage report.
Old May 18, 2011 | 05:51 PM
  #94
CrAnSwIcK's Avatar
for disassembly, you need to destroy the case cap (MD746157)...other than that i have listed everything that "should" be replaced since it's apart(unless there is synchro wear or gear damage)...and make sure to check the shim tolerance on the differential. And come to think of it, you may want to replace the snap rings on the end of the shaft, where you replace bearings
Old May 18, 2011 | 07:50 PM
  #95
2 seals had to be replaced for mine. The cap an the input seal. Just fyi
Old May 19, 2011 | 05:18 AM
  #96
turboart's Avatar
Thx for the info. ill get pn on everything when i know more of whats goin on. I may be getting everything compensated for so we shall see how it ends up.
Old May 29, 2011 | 02:08 PM
  #97
ralliart610's Avatar
turboart, how did the bolts fit? Was any grinding needed? I dont want mine turning into an all day project, lol. Luckily my buddy has a tranny shop so ill be doing it there on the lift, but i just need to know if the bolts are right or not. As sson as i find out, install will begin.
Old May 29, 2011 | 03:59 PM
  #98
turboart's Avatar
Well are upgrading your clutch cuz I would upgrade th cmc too just incase I got mine waiting but I havent got anything in cuz im waiting on my new tranny to show up but I imagine bolts will need grinding but I haven't checked yet ill get on that just to see. The heads may need some grinding too the mine are the height and from i see they clear the clutch disc fine but the cm flywheel has so lil room I may do it for some extra measure
Old May 30, 2011 | 08:27 AM
  #99
I think ill wait and see if I need to upgrade my cmc. I just got the fx100 CM clutch. I dont think I need to upgrade the cmc for it.
Old May 30, 2011 | 09:04 AM
  #100
CrAnSwIcK's Avatar
probably not.
Old May 31, 2011 | 03:45 AM
  #101
Ralliartize It's Avatar
WRONG!!! The OEM CMCs are so ****ing weak you can bet your *** you are going to blow it very soon.
Old May 31, 2011 | 09:31 AM
  #102
CrAnSwIcK's Avatar
I'll let you know very soon, i'll have my ACT 2100 is going in this weekend, i wouldn't think the CM "stage 1" would be stiff enough to blow the master cylinder..
Old May 31, 2011 | 09:48 AM
  #103
Agreed, I dont think the "stage one" is much different than stock.
Old May 31, 2011 | 10:24 AM
  #104
I don't think you gentlemen truly understand the weakness that is our CMC....save yourself future headache and swap out to the Evo 8 CMC. There are plenty horror stories on here dating back years of guys blowing their CMCs once they start messing with aftermarket clutches.
Simply put the o-ring in the stock CMC can't take the additional pressure.
Old May 31, 2011 | 01:06 PM
  #105
Rumblefish237's Avatar
Just listening in
Im gonna change my clutch in August and I am just listening in on this thread to see how it goes for you guys. Thanks.
