high rpms bad mileage?
Old Sep 9, 2011 | 12:23 AM
  #46
k3lv's Avatar
Originally Posted by CrAnSwIcK
the factory map isn't even tuned for 94, it's not really cleaner, octane is more the compressability rating of the fuel, and our engines don't need high octane fuel, cause the engine is not a high compression engine. When you start modifying your AFR, increasing compression, or running boost then you may need to change your ignition timing and increase octane to prevent knock.
This.
Old Sep 9, 2011 | 05:42 AM
  #47
Beardly P's Avatar
Hail to the Beard
Originally Posted by Raikiri
To save yourself some more money you don't even need premium in the car if its all stock...
This.
Originally Posted by Vro0oom
I've noticed a slight increase in gas mileage comparing 87 to 94 plus it's a cleaner gas, so to me the extra $10 a full tank is worth it
I'm sure I don't 'need' it but I definitely want it :P
You're just wasting your money. In fact, you could probably save $400-$600 annually (possibly more considering your driving habits and how often you fill up) by not using premium. With all the money you would save, you could appropriately mod your car to benefit from or require the use of premium (because you "want it").
Old Sep 9, 2011 | 11:58 AM
  #48
2006_RA's Avatar
Yeah, when I did chemistry lower octane gave better mileage vs higher octane for a given engine. Then came the internet and suddenly higher octane gave better mileage than lower octane.
How do people measure their mileage is what I would like to know ?
I do it based on filling up all the way to the brim then resetting the trip meter, driving and seeing how much it takes to fill to the brim once more and recording the reading on the trip meter.
I fill to the brim because that is the only way I know how much fuel has been used, any other way and I dont know how much fuel I am starting with.
Old Sep 9, 2011 | 12:09 PM
  #49
Beardly P's Avatar
Hail to the Beard
I track my MPG with Fuelly.
Old Sep 9, 2011 | 06:05 PM
  #50
Vro0oom's Avatar
But I like filling up my car and pretending I've got a turbo under my hood.
Old Sep 9, 2011 | 06:07 PM
  #51
Vro0oom's Avatar
I track my fuel the same way as most people. Using your advanced method of fuel consumption
Old Sep 9, 2011 | 09:07 PM
  #52
CrAnSwIcK's Avatar
http://www.ebay.ca/itm/Universal-Tur...item4cf9fb4e1c
Old Sep 9, 2011 | 09:29 PM
  #53
Beardly P's Avatar
Hail to the Beard
Old Sep 10, 2011 | 08:22 PM
  #54
Vro0oom's Avatar
I'll have to combine that with the cigarette lighter sound effect for maximum benefit
Old Sep 10, 2011 | 09:08 PM
  #55
CrAnSwIcK's Avatar
for sure...then you could pull a cranswick, and run triple gauges that are wired for power, but don't actually do anything...yeah it's embarrassing, but they will serve a purpose down the road, lol!
Old Sep 11, 2011 | 02:16 PM
  #56
veloracer's Avatar
I've been tracking my mileage for 11 months 15 days now using an app called aCar on my Droid. Here are my full mod list and car history which may all have an effect to the mileage overall:
Mods
  • Eibach Pro-kit Lowering springs (1.4" front, 2" rear (I think))
  • 17" Drag wheels 215/45/17 summer (stock wheels with snows winter)
  • EBC slotted\dimple rotors
  • Blox front roll stopper
  • RRM Timing box (89 Octane fuel)
  • 63mm TB
  • AEM CAI
  • Aasco Aluminum lightened flywheel
  • Exedy stock replacement clutch
  • lower SS clutch hardline
  • upper SS clutch line
  • Brass shifter bushings
Car
  • 2004 Ralliart with Sight Sound option
  • Owner since May 2005 with 5000 miles on the clock (bought from Dealership as a Sales Manager driven car)
  • Engine\car have 108900 miles on it
  • Transmission was rebuilt only has 2000 miles on it
  • New timing belt kit done a 90000 mark
  • Regular maintenance done by me including valve adjustments
I commute daily 72 miles round trip with 60 miles all highway. I drive @ 3495 rpms (just below 3500 since Mivec kicks in @ 3495 rpms) usually that is 72 mph. I do drive pretty lively, no burnouts, but do get shift points up to 6500 rpms on occasion. Getting on the highway is fun .
So with all that said I average 25.699 mpg which I'm ok with.
EvoOtto
Oct 29, 2015 07:13 PM
reliablefr
18
Aug 30, 2012 11:46 PM
Melon
Feb 8, 2012 11:16 AM
NismoSkylineGTR
Nov 3, 2002 01:08 AM
