Weird jerking while driving...
Old May 13, 2012 | 05:37 PM
MarkChamorro's Avatar
Okay well I was coasting going 45 in 5th gear, and then my car started jerking as if I was on then off the accelerator repeatedly. Then I took my foot off then back n and it went away. It has done this maybe four times recently, but the last one was too notcieable to pass up. What could it be, also I know I need to re-do valve lash but idk I was looking to see if there is something else I should check, just in case.
EDIT: http://www.buzzle.com/articles/sympt...on-sensor.html
I'll base off of this article, should I be okay with that?
Old May 14, 2012 | 01:38 AM
lanzerralliart's Avatar
EvoM Super Moderator
It could be the throttle position sensor or the throttle cable could be needing lubrication.
Old May 14, 2012 | 05:22 PM
I know I have a new throttle cable installed, but I'm a noob so must ask this. How do I go about checking if the throttle position sensor is working properly and I'll figure it the lubrication lol
Old May 14, 2012 | 08:00 PM
keithislegit's Avatar
How do you lube it?
Old May 14, 2012 | 11:54 PM
Originally Posted by keithislegit
How do you lube it?
Where the cable connects to the throttle body, lube or grease there. Anyone correct me if I'm wrong. But I believe that's it, google probably has the answer lol
Old May 15, 2012 | 02:16 AM
Clean the contacts in the connectors ,meter the wires, check for continuity, and then for a short to the ground.
Old May 16, 2012 | 08:20 PM
Resurrected RA's Avatar
I always use lube when jerking occurs...how did no one comment on that before me...
Old May 16, 2012 | 10:48 PM
CrAnSwIcK's Avatar
lube does make it better...
Old May 17, 2012 | 12:13 AM
Lmfao idk how I didn't think of that
Old May 17, 2012 | 05:28 AM
2006_RA's Avatar
I saw the thread before anyone had replied and the temptation was tremendous, but I was trying to play nicely with others for a change.
Old May 23, 2012 | 09:08 PM
mikemike396's Avatar
I had these same symptoms. Ended up cleaning the pins on the TPS and everything is fine now. Also put Diametric grease in the connector.
Old Jul 5, 2012 | 08:46 PM
04rallikid's Avatar
Its a potentiometer with a 12v signal not 5 volt like most senors. It should change from near 0 at idle and to near 12 at wot
Jordan2447
May 14, 2017 06:34 PM
Jordan2447
Lancer Tranny/Drivetrain Tech
May 12, 2017 11:28 AM
Virtual
Aug 16, 2016 07:02 PM
Ralli_Red
Aug 8, 2015 05:45 AM
