Pulley Installation Issue
Old May 21, 2012 | 12:28 PM
RalliartN's Avatar
got mine from Partsource, the numbers on the package are 4060725 and 6PK1840, its a "poly-v gatorback"
Old May 21, 2012 | 12:32 PM
Raikiri's Avatar
you can get them from any autozone or local parts store as long as they have the size in stock.
like previously said its a 6PK1840 belt
right now im using a gatorback on mine and it seems pretty solid
Old May 21, 2012 | 01:19 PM
Resurrected RA's Avatar
Thanks fellas, I had the PN on a piece of paper in the glove box...I must have researched previously...
Old May 30, 2012 | 01:48 PM
kapitolralliart's Avatar
Quick question, sort of ...Is anyone running a UDP with a mini battery kit?
I was interested in doing an intake upgrade similar to RalliartN, but I don't want to lose power by having a UDP and mini battery. Any input?
Old May 30, 2012 | 01:54 PM
slc-ralliart's Avatar
I know Otter ran a mini battery along with udp on his Ralliart. I don't think he had any problems. His only problem was I don't think the mini battery survived the rough winters.
Old May 30, 2012 | 06:08 PM
CrAnSwIcK's Avatar
that, and you would not want to run a power hungry sound system...
Old May 30, 2012 | 06:21 PM
RalliartN's Avatar
I have the UDP too. I don't know what you mean by losing power. I can have the air-con on, the lights on high, and the stock sound system cranked - the car operates normally with the mini-battery. The only thing different is, when turning the key to start, the engine doesn't snap to life immediately, it cranks an extra half-second or so then fires up. You might not notice it, I am very picky; not an issue.
Old May 30, 2012 | 10:48 PM
OK. Thanks guys. That clears it up for me. Got stock S&S package and not planning to upgrade so
Old May 31, 2012 | 05:13 AM
bakuro117's Avatar
A little off topic but does anyone know what the differences are between the UDP on ebay and the UDP that RRM offers?
Is one better than the other or is there not really a difference? If I get a better setup with the ebay one and the gatorback belt then I will go that way. But if the RRM one is better I guess the extra $10 would be worth it.
Just curious.
Old May 31, 2012 | 06:21 AM
lanzerralliart's Avatar
EvoM Super Moderator
I don't really see a difference , rrm's pulley was the same price of the eBay pulley when it first came out :/ I hav te rrm pulley but if I was buying it again it would be the eBay one. I can't see myself paying double or the same thing.
Old May 31, 2012 | 07:51 AM
bakuro117's Avatar
Well it doesnt look like the ebay one comes with a belt and by the time shipping for both comes out they'll be around the same price (give or take a few bucks) so I was just wanting to be sure that one wasnt better quality or something.
Thanks Lanzer
Old May 31, 2012 | 09:41 AM
bakuro..i found the 725K6 belt at vbeltsupply.com. If that's the correct belt, its only $11.91, not sure how much shipping to you would be though.
Old Jun 4, 2012 | 05:54 PM
Myszkewicz's Avatar
That's the belt (725K6 or equivalent) I've been using with my UDP since I put it on almost 100000 miles ago.
Old Jun 5, 2012 | 11:17 AM
MitsuJoe's Avatar
Awesome that this pulley is still a popular mod. I am sorry for your trouble with getting it off. It sounds like you found some very creative way to get it off.
I can tell you that cost of CNC and material has more than doubled since 2005. This alone should help justify the price. Also the pulley is made in the US last time I checked so please keep that in mind.
Old Jun 25, 2012 | 01:07 PM
sway311's Avatar
If I dont have a torque wrench, can I just tighten the bolts as much as I could but not to the point that I will go crazy tight with em?! LOL!!!
