Pulley Installation Issue
Old Aug 21, 2012 | 07:47 AM
  #61
MitsuJoe's Avatar
Mine was on an EVO.
Although I had plenty of fun developing the UDP for the Ralliart!
Old Aug 21, 2012 | 08:31 PM
  #62
keithislegit's Avatar
Originally Posted by CrAnSwIcK
when i broke a bolt off in my block i has to drill it out completely, ream it to the peaks of the threads, pick all the bolt threads out with a scribe, and then tap it...
If all else fails, is have to re tap it? What size bolt did you replace it with?
Old Aug 21, 2012 | 08:54 PM
  #63
CrAnSwIcK's Avatar
same size...i think you misunderstood the procedure...by tapping, i meant chasing the threads...
Old Aug 21, 2012 | 09:48 PM
  #64
truthdweller's Avatar
Veteran: Navy
Keith, he was able to save the original threads, and cleaned them up by chasing them with the tap.
Old Aug 24, 2012 | 03:36 PM
  #65
RacerX-Ralliart's Avatar
Damn what the hell were you using to tighten them a breaker bar or impact gun.. Okay okay enough bashing this must suck I'm sure you are driving it on 3 bolts though right? I would cause i really need my car but of course I would have fixed it the day of.. If you can find a reverse drill bit your golden just punch a guide mark in the middle and it turns left and grabs it and turns the extractors and easy outs you have to put a lot of pressure for it to grab.. I drilled a bolt ONCE and chased it but it didn't turn out the way I wanted it to but it still worked
Old Aug 25, 2012 | 01:33 AM
  #66
Yeah, I used an Impact gone that had like... 600 ft lb of torque or something like that. Well, that's what my friend told me it had.
Old Aug 25, 2012 | 05:27 AM
  #67
RalliartN's Avatar
This ^^ more often than not. I've fixed these things on cars and motorcycles.
Lots of heating and cooling cycles tend to make threaded joints fuse together (unless there was anti-seize compound on them). Sometimes an easy-out just acts like the bolt shank that broke off - you can't torque it enough to break the threads loose.
So here are options based on my experience, one of them will work:
1. what Crans said above
2. heat the pulley area with a torch then screw in the easy-out and try to extract broken piece
3. if the broken bolt has hardened and is difficult to drill into with a high speed bit, drill the broken piece out with a stellite bit and re-tap. Stellite is a material that retains its hardness at the high temperatures that soften/weaken bolt steel. The stellite bit's tip looks crude and dull like a concrete drill, but it is supposed to because that way it creates friction that heats the broken bolt until it's soft enough for the stellite to drill thru easily. I use this technique for exhaust header bolts that snap off flush with the head.
4. Into the broken bolt, drill a smaller hole than the original and re-tap for a smaller diameter bolt. This is much better than nothing. Use a grade 8 bolt and you'll be fine. Should be no balance issue because, overall, there is still the same amount of material there.
p.s. MitsuJoe was a pioneer for RA mods way back when, nice to see him looking in.
Old Aug 25, 2012 | 01:58 PM
  #68
........ Are you messing around? Why would you use something that powerful on such small bolts?
Old Aug 25, 2012 | 02:19 PM
  #69
Resurrected RA's Avatar
Nope, Keith is legit.
Old Aug 25, 2012 | 02:37 PM
  #70
lol. Yeah, I'm serious. Reason was because I didn't have any wrench or hand sockets and only had the gun and I had only 15 minutes to finish it at 2 in the morning and I wanted to do it quick. Didn't know it was going to snap.
Old Aug 25, 2012 | 05:13 PM
  #71
Lmao well we learn from our mistakes right..
Old Aug 25, 2012 | 05:41 PM
  #72
That's exactly it, when I hear about someone twisting wrenches on their cars, it makes me happy. Regardless of the outcome.
Old Aug 25, 2012 | 09:41 PM
  #73
CrAnSwIcK's Avatar
lol @ 600 ft-lb
Boeing C-17 Globemaster III....wheel nut torque: 250 ft-lb
Old Aug 25, 2012 | 10:15 PM
  #74
Thomar's Avatar
lol @ 600 ft-lb
yeh, and probably one cotter pin holding it all in place.
Old Aug 26, 2012 | 02:26 AM
  #75
lol @ 600 ft-lb
lol. I'm not sure how strong that impact gun was. I was just going by what my friend said. I don't even know if they make impact guns that strong. I'm not so tool savvy. It was one of those portable battery powered snap-on ones.
