Car stalls when AC is on
Old May 29, 2012 | 10:28 AM
MarkChamorro's Avatar
Okay well I noticed if I start the car while my AC is on (setting 1) if I go to neutral it will stall. But after 10 mins or so I can turn it on full blast and no negative effects. I understand that the car may need to warm up etc. but for it to stall, that can't be normal... Or maybe it is
Old May 29, 2012 | 10:33 AM
fastyouth1313's Avatar
How old is your battery? Or your alternator could be going out.
Just my 2cents
Old May 29, 2012 | 11:03 AM
maevo8's Avatar
also it might be iac going out thats what happened to me and i replaced it and works good now
Old May 29, 2012 | 07:59 PM
I was thinking alternator, solely due to the fact that my buddy recommended a new alternator since it looked a little old when I first got my car. Also it takes a few, maybe 2 seconds to turn over the car with the Key in the ignition spot.
Old Jun 8, 2013 | 11:57 AM
terrorz75's Avatar
I just started getting the same problem. The car drives normal and when I turn my AC on the idle starts to flutter and then stalls.
I have 2010 GSR only 9090 miles on it got a Cobb test pipe, Greddy exhaust, Cobb intake and turbo inlet with a stage 2 program and a defi boost gauge.
I rarely drive it, can it be the battery or do I need a new IAC? I didn't have this problem before until the beginning of this year.
Old Jun 8, 2013 | 12:01 PM
terrorz75's Avatar
Also, Where and how do I check my IAC on my car? Is there a How To for that.
I really love my car but if this keeps happening I'm going to have to sell it and I barely got a chance to really drive it hard.
Old Jun 9, 2013 | 04:02 AM
Awe, brought back one of my first posts. I fixed it by doing the ol' ecu reset, and let it learn with the ac on and off
Old Jun 9, 2013 | 08:26 AM
terrorz75's Avatar
Really? Ok, I'll give that a try. Thanks so much.
Old Jun 9, 2013 | 09:52 AM
terrorz75's Avatar
It didn't work the first time when I pulled the battery, but I only left it off for about 1 minute. Should I have left if off longer?
I'm going to try to download a new map from Cobb and hope that resets everything. Nothing worked I tried updating the ECU and took the battery off for about 10 minutes and nothing is working.
But here's the thing, I went through the same issue during winter when turning just my heater on during cold weather. It doesn't happen right away only after I drive it for awhile.
Any other suggestions? I read in other forums that it can be the IAC valve but I've checked online and there are no valves for my year but then there are other people say that it can be the alternator and battery can it also be the MAF sensor?
Old Jun 10, 2013 | 12:04 AM
I just realized you have an X. I'm not scooting you away or anything but start a thread about this on the Evo X sub-forum on this site. Also, idk if you're equipped to, but send over your tuning file (rom) to a remote tuner, Tom at TSCOMP etc. and they can see if something is up in regards to a tune. Or they might even just fix it with a tune.
Old Jun 12, 2013 | 09:45 AM
terrorz75's Avatar
Hey Mark, thanks for the advice. I figured out what was wrong and I'm getting it corrected. I'm waiting for a Heat shield to come in. The idle and stalling was due to the AC fan blowing hot air into my intake since I have a open cone filter. I tested it out by put something in front to block the hot air blowing in to the intake and then I removed it and the engine stalled. So I'm getting a cheap heat shield from Summit racing.
Old Jun 12, 2013 | 10:59 AM
Oh wow. What a crazy situation lmao would've never crossed my mind. Thanks for telling me what happened! That's a nice easy fix
Old Jun 12, 2013 | 05:59 PM
terrorz75's Avatar
One last question, do you know where I can get a heat shield? The one from Summit doesn't fit and it's too bulky.
Old Jun 12, 2013 | 10:08 PM
Angry
You can try getting OEM from Mitsubishiparts.net. Also PM a couple of vendors. They'll be more than happy to help you out with a purchase bud.
rich3389
Sep 8, 2024 07:27 AM
PlanoEvo
Aug 12, 2013 09:16 PM
3011carlos
Jul 18, 2013 02:50 PM
HN7
Sep 6, 2012 05:01 PM
LancerEVOmann
15
May 4, 2005 02:31 PM
