car dying
ok first off my car has been acting weird at idle. idling at 1k-1.1k then going down to about 700 and it will stay there but i kinda spikes on its own to about 9-1k from the 700. lately when coming up to stop signs i throw my car in "nuetral and it almost dies completely like almost sputttering if u will. today on my way home my car acutally died coming up to a stop sign when i was completly off the gas and on the brake, also at this time i lost my powersteering annd everything else as my car died... now there was two lights that came on but did not stay after i started up my car to move from the busy *** intersection. i believe it was the battery and oil light but i cant remember it happened pretty fast . anyone have any idea on what this could be. maybe the egr er egr valve? er anythign i checked the oil and all fliuds INCLUDING gas and everythings good. i have an intake n header n exhaust do u thing im gettig to much air not enough air er too little gas too much gas? no idea please help i want to attend to this problem tonight. thanks for taking some time out to read this.
How's the tension on the serpentine belt?
If power steering dies its normally the belt... And the low idle could be the alternator, wich is also on the same belt.. So If its slipping it could be kicking out both from time to time.
if the engine isn't turning, you don't have assisted steering that's typical, if you don't have power steering when the engine is running, if the belt is on, then the pump is toast, but i think your issues lie elsewhere...
Are there any DTC's? (check engine light), try resetting the ECU...
fostytou
359
Oct 23, 2025 09:54 AM
jennz03
Lancer Troubleshooting
Feb 20, 2017 08:15 PM
BostonLancer
21
Nov 2, 2002 12:04 PM
