New oil pan?
Old Jun 15, 2013 | 10:33 AM
mikemike396's Avatar
New oil pan?
So how thick is the oil pan? Should I be concerned about this rust? Would it make sense to put a new one in as a preventative?
Attached Thumbnails New oil pan?-photo-1.jpg   New oil pan?-photo-3.jpg   New oil pan?-photo-4.jpg   New oil pan?-photo-2.jpg
Old Jun 15, 2013 | 12:11 PM
RacerX-Ralliart's Avatar
Looks pretty bad I think cranswicks pan is worse.. I would lightly sand some of the surface off and spray some high quality rust converter.. Not to sure about sanding it though don't want you to make a pin hole or anything
Old Jun 15, 2013 | 01:46 PM
CrAnSwIcK's Avatar
yeah, that's nothing, mine's way worse...
when it starts looking wet then worry, unless you run over a boulder, or a cinder block it it won't just dump the contents of your oil pan all at once, it should be fine for a while...if you have cash to spare it never hurts to do some preventative maintenance...otherwise pay the the bills and keep your eye on it
Old Jun 16, 2013 | 09:08 AM
Do you think it would be okay to sand this down? And put a few coats of Rust-oleum on it?
Added more pictures. Upclose.
Old Jun 16, 2013 | 05:01 PM
Rocksolid58's Avatar
I recently replaced my oil pan on my 03 Evo. My factory oil pan was leaking oil thru a rust spot similar to the ones in your pictures.
Old Jun 17, 2013 | 07:28 AM
Did you have to drop the exhaust to slide the old pan out?
Old Jun 18, 2013 | 05:50 AM
Yes I just unbolted the down pipe.
Old Jun 18, 2013 | 06:30 PM
Updates. Wire brushed it really good and sanded it down with 80gt paper. Then put about 4 good coats of engine block paint. Hope it holds up.
Attached Thumbnails New oil pan?-img_0555.jpg   New oil pan?-img_0556.jpg   New oil pan?-img_0557.jpg   New oil pan?-img_0558.jpg   New oil pan?-img_0560.jpg
Old Jun 18, 2013 | 06:42 PM
CrAnSwIcK's Avatar
looks good, i was thinking of doing mine with that spray on bed liner for trucks, or like rocker guard or something, but i was worried about high temperatures affecting the coating...
Old Jun 18, 2013 | 06:44 PM
Yea I was debating getting that too when I was at AutoZone, but none of them seemed to be able to handle the heat.
blitzkreig
May 16, 2017 08:32 AM
David Buschur
83
May 27, 2016 07:39 AM
gothp?
Jan 29, 2016 08:35 AM
gui dube987
Feb 25, 2015 08:19 AM
RS2
14
Jul 26, 2005 03:11 PM
