Idling problems and Car shutting off at stops
Old Dec 3, 2014 | 12:54 AM
Raikiri's Avatar
Wasn't sure if this is the one you guys are talking about
Attached Thumbnails Idling problems and Car shutting off at stops-117269373_zpsa308b99a.gif
Old Dec 3, 2014 | 05:41 AM
bakuro117's Avatar
yup thats the one. When my car was doing this I swapped that solenoid with one off my spare engine and everything was perfectly fine again.
Old Dec 3, 2014 | 07:41 PM
johnnycage's Avatar
Jah, vacuum pressure issue for sure.
Old Jan 12, 2016 | 10:19 AM
hozej's Avatar
Late to the party but dealing with the same issue
Found this thread while trying to diagnose my 2004 sport back RA. Thank you for having posted this bit. I am having the same problem with the low idle and car shutting down randomly at stop lights. However I have some additional symptoms. Non of which have triggered a code that I am aware of.
-Occasionally when driving the lights dim and I can hear the heat/air slow/stutter when I let off the gas. (this also happens at idle when the cooling fan randomly & irrationally kicks in.)
- When the car stalls (stopped @ a light and RPM drops 500 - 0) anything electric is gone? Radio channels clear, Tripometer goes back to zero, no lights, locks, windows... all dead. If the key is removed and reinserted, everything goes back to normal for an hour, day or even a week? No real patter that I have noticed.
Now here's another head scratcher. The headlights when left on automatically shut off with the car when the key is removed (Normal). Now if the car stalls and I remove the key (all power being gone) the lights left in the on position still drain the battery? So it's basically like turning the lights on when the key is out, without getting light?
Once, while driving, the car would not go past 3000 RPM. Per advice previously posted in one of the threads here, I fiddled with the mass airflow sensor and it has never happened again?
Again, Thank you in advance for any insight you can offer. The car is just turning 98,0000 and has been a great little grocery getter. Even dealing with the above issues for the last 8 months, it's yet to leave me stranded.
Old Jan 13, 2016 | 02:45 PM
CrAnSwIcK's Avatar
scan it to be sure the CEL is not burnt out, lol...
sounds like an electrical problem...make sure your battery terminals are tight. any other symptoms you can think of?
Old Jan 14, 2016 | 06:15 AM
hozej's Avatar
Thanks for the reply Cranswick, You are truly appreciated!
Yes I purposely drove with the gas cap off see if the CEL is working and throwing a emissions code. All is good there.
So far I have cleaned and tightened the battery terminals, checked solenoid (as you previously advised in the post, Thank you) and checked for codes (none showing). Someone I was speaking with suggested that it may be a relay switch in the ignition system which is buried in the steering column? This is my daily driver and I am not familiar enough with the electrical workings of the ignition system to begin teardown based on a beer induced brain storming session. It was also suggested, given the odometer (98K) that the timing could have slipped but I have found nothing in my research that relates timing to completely random electrical failure without obvious engine problems?
It does seem that I have been putting a lot of gas in it lately. However it typically has a power loss which resets my tripometer so I am now in the process of counting miles on the odometer to see. Any thoughts on the ignition switch theory?
Will424
Aug 8, 2015 08:14 PM
mitlan
21
Jan 2, 2012 08:26 PM
JaReDbOy
15
Mar 17, 2006 08:14 AM
webguy330i
Jul 21, 2005 04:46 PM
reefro
Apr 7, 2005 07:32 PM
