Need help car shutting off while driving
Old Jun 27, 2015 | 08:00 AM
Will424's Avatar
I have a evo 8 and the car shuts off while im driving. 3 times when i was at a stop and 1 time while i was going 40mph. Anybody know what the issue can be? Mods- 850cc injectors, ets intercooler, aftermarket piping, tial bov, tbe, sri, dyno tuned on stock turbo @ 25psi 350whp. Any input would be great!
Old Jun 27, 2015 | 09:24 AM
dothacker81's Avatar
take it to an EVO mechanic.
Old Jun 27, 2015 | 01:20 PM
lostsoulsevo's Avatar
Are you tuned for speed density?
Old Jun 28, 2015 | 06:34 AM
winvargh's Avatar
Yes, it is tuned for speed density.
Old Jun 28, 2015 | 06:47 AM
Ev0ikon's Avatar
Did you contact the "tuner"? What did he/she say? Did the car throw any code/check light?
Old Jun 28, 2015 | 09:07 AM
winvargh's Avatar
The tuner is no longer available. It was tuned very long ago. No codes or check engine light. I was thinking maybe the iac valve? I also have a cop, but not sure what plugs to use. The cop can help with idle correct?
Old Jun 28, 2015 | 09:12 AM
winvargh's Avatar
The car idles normally at 1,000 rpms. The A/F ratio ranges between 14.5-15. It usually stays around 14.7. When the idle fluctuates, A/C on it goes to around 800 rpms. The A/F ratio is around 11. When I am cruising at a maintained speed, the A/F is around 14.7, when its in boost and at WOT it is around the high and low 11s.
Old Jun 28, 2015 | 09:22 AM
winvargh's Avatar
Also, the tial BOV I have is supposed to be recirculating from what I've heard. Is there supposed to be a connection from the BOV to the SRI? Because it does not have the connection.
Old Jul 7, 2015 | 02:47 PM
gqcode's Avatar
Veteran: Air Force
Sound like your Idle Air Control is going out. MY Evo was kind doing the same. There's tread about the IAC and test you can do on youtube. I brought a IAC off the evom forum at $85, brand new it cost around $430. Let me know if you need more help! MY car was basically stalling at red light or at a stop sign, the problem got worse and would just stall while driving!
Old Jul 7, 2015 | 03:15 PM
kaj's Avatar
kaj
anyway to log what you fuel trims and IACV % are?
Old Jul 7, 2015 | 03:19 PM
winvargh's Avatar
Yes, help would be appreciated. I can't get a hold of an iac. The oem one is very costly. Can someone give me a link?
Old Jul 7, 2015 | 03:33 PM
kaj's Avatar
kaj
http://www.rockauto.com/catalog/more...nid=435&jpid=0
Idle Air Control Valve Direct Fit OE Style Valve For Mitsubishi - - Amazon.com Idle Air Control Valve Direct Fit OE Style Valve For Mitsubishi - - Amazon.com
Old Jul 7, 2015 | 05:32 PM
gqcode's Avatar
Veteran: Air Force
https://www.evolutionm.net/forums/sa...art-out-4.html
This should help it come from another member of evom and from an Evo 8. The seller is asking to make an offer. I would rather go with an IAC made for and EVO than a cheap replacement. I did that first and the car idle was all over. then I would get the high idle engine light malfunction. Good thing I had order from someone on the forum. It easy to replace just take your time. PM me if you need more help.
Old Aug 8, 2015 | 06:39 PM
winvargh's Avatar
So, the car still has been shutting off. I found out the ignition fuse keeps blowing. I have to keep replacing it about 5 times a day if I have to drive the car. I noticed that after I put the COP in (spoolin up) this problem has been happening. I have my old coil packs, but the only thing is I threw out the old spark plugs. I am unaware of what the gap was. I bought numerous plugs, none worked. The car knocked on every single trial. I bought 3 different plugs. All 3 plugs worked with the COP. I have also replaced the IAC. I also thought the stock ground wires were fouled, so I bought a new grounding kit (hks). After a straight hour of driving the car shuts off with a 15 amp fuse. With a 20 fuse in there, it shuts off in about 2 hours of straight driving. I also cleaned the battery terminals, as I was reading corrosion can cause the car to stall. I even tried to gap the plugs to every gap possible. No change. Can anyone help me?
Old Aug 8, 2015 | 06:43 PM
winvargh's Avatar
By the way, will424 is the op. We both own the same car if anyone was wondering. Lol.
