Engine Mounts
Old Feb 10, 2015 | 09:02 AM
JTCB's Avatar
Engine Mounts
I have to do my engine mounts for the 3rd time. Kinda getting tired of throwing money away. I wanted to get the polyurethane ones but really not looking forward to all the vibration considering I do almost an hour of traffic everyday. So I think I wanna try the window-weld crap and see if it can be durable. From what I can gather its a lot less stiff than the urethane ones and shouldn't cause to much vibration in the cabin. What can I use as a primer to make the window weld properly bond to the rubber so that it lasts.
Old Feb 10, 2015 | 08:49 PM
CrAnSwIcK's Avatar
devcon makes a primer, but all I do is make sure the windo-weld goes all the way through the bushing so that both halves become one piece through the holes in the original bushing...
Old Feb 11, 2015 | 03:28 AM
JTCB's Avatar
ohh youve done it before? Can you shine in on the cabin vibration?
Old Feb 11, 2015 | 04:14 AM
bakuro117's Avatar
I did it the same way crans said. And I didn't notice anymore vibration with the rear mount. The front mount added a tiny bit when your sitting still.
Old Feb 11, 2015 | 05:44 AM
JTCB's Avatar
When you say a tiny bit. Is it bothersome? I'm not exactly sure what you mean crans. You didn't fill it to the exterior like so?
or you just filled in the 2 gaps to make it like one piece. Kinda like this but properly filling the holes up and making it even with the rubber?
Old Feb 11, 2015 | 06:13 AM
bakuro117's Avatar
see the thin rubber inside the mount? Cut that out so that when you fill it with window weld its one piece all the way thru, instead of a piece on each side.
And I just got some extra vibration in the steering wheel when sitting still. its not bothersome at all. I'll soon be filling ALL my motor mounts and deleting the balance shafts. So I might have some more vibration then but the front and rear motor mounts weren't bad at all. My wife never even complained about it, however she did complain when the rear mount went bad. that was ridiculous.
Old Feb 11, 2015 | 06:26 AM
CrAnSwIcK's Avatar
yeah I filled the thing right up, both sides, through the middle...mine looks like the first pic....
Old Feb 11, 2015 | 07:05 AM
JTCB's Avatar
I know what she means, mine is pretty much finished again its crazy how the engine rocks you especially feel it when you turn off the car and it makes a hole bunch of noise. btw thats not my engine mount the one I'm ordering doesn't have that thin layer. I just ordered the engine mount kit on ebay cost me 250$ shipped for all 4 mounts. Ill try reinforcing them all a little and there should really be no play after.
EvoDan2004
30
Sep 23, 2013 01:57 PM
CatalystGod
May 13, 2009 09:16 AM
Speed Element
10
Jul 8, 2008 05:03 PM
4ringturncoat
Mar 4, 2008 05:55 AM
TTP Engineering
15
Jul 11, 2007 02:48 PM
