Outer tie rod replacement
Old Mar 10, 2015 | 05:01 PM
JTCB's Avatar
Quick question. I had a toast outer tie rod. I decided to change it Im receiving a full suspension kit from rockauto but its only coming in 2 weeks so I decided to go and get a cheap 15$ tie rod to hold me over till then.... Since I changed it its making a weird clunking type noise. When I take off in first gear and let off the gas and the car falls on itself it " dont know how to explain it better than that " it makes a clunking sound and then when I go back on the gas it clunks again and then goes away. I torqued it down as hard as I could with a wrench...any ideas..??
Old Mar 10, 2015 | 06:35 PM
JTCB's Avatar
Been checking everywhere... hard to find information. Is it possible that I overtorqued it.?
Old Mar 11, 2015 | 05:37 AM
2006_RA's Avatar
Clunking noise could be the track control arm bushing or ball joint, the axle, link ... get the car on a jack and check.
Old Mar 11, 2015 | 07:35 AM
bakuro117's Avatar
Was the end you put on greased?
Old Mar 11, 2015 | 10:39 AM
CrAnSwIcK's Avatar
check that the transmission crossmember isn't broken in half...
Old Mar 12, 2015 | 05:47 AM
JTCB's Avatar
What do you mean by transmission crossmember?? I didn't know we had one. Im only aware of the crossmember that the bottom engine mount sits on..
Old Mar 12, 2015 | 11:49 AM
CrAnSwIcK's Avatar
the crossmember that goes front to back under the transmission, that the front transmission mount is bolted to, it's also got the front tow loop and center jacking point on it...the main crossmember, or "K frame" is the main one that the rear mount, steering rack and control arms are bolted to...
240Z TwinTurbo
Sep 2, 2018 11:28 AM
krzys4
Jul 7, 2016 06:49 AM
304MR
20
Mar 15, 2013 12:02 PM
mcm308
33
Apr 5, 2012 05:11 PM
wrxedout
16
Mar 12, 2008 02:08 PM
