Clutch problem?
Old Jun 9, 2017 | 01:18 PM
kouroshb26's Avatar
Clutch problem?
Recently I have been having troubles with my clutch. It feels kinda loose/mushy. Thus when I start the car, I can't put it into gear. I am not sure if the problem is my clutch is all used up and needs a replacement or if it is a hydraulic issue(not sure if there is hydraulics involved). One thing that seems to fix it for a bit is that I can push the clutch in couples of times and it kinda gets stiffer so I can put my car into gear.
Furthermore how hard is it to change a clutch. Should I do it myself. I have a limited amount of tools but have training in being a mechanic.
Thanks
2005 Lancer Ralliart
Old Jun 9, 2017 | 01:21 PM
4G63_EVO's Avatar
That sounds like the exact problem my friend had recently on his civic SI, Clutch master cylinder was shot!
Old Jun 9, 2017 | 01:32 PM
kouroshb26's Avatar
Yeah, I looked into it a bit more and I think you are probably correct. Is it a hard job?
Old Jun 9, 2017 | 01:44 PM
4G63_EVO's Avatar
Fairly easy, but whats difficult is fitting your hands into the tiny space to wiggle it out
https://www.evolutionm.net/forums/ev...-cylinder.html
Old Jun 11, 2017 | 05:01 AM
RalliartN's Avatar
First, bleed clutch line. Thoroughly.
Check brake cylinder for fluid leak. If no leak but problem persists, might be internal leak so pressure can't hold, so get a new cylinder. There is an excellent thread in our RA forum from some years ago, with pics, investigating this issue. Search. And (sigh) the link the previous poster provided is not for your car, and don't bother looking up "Civic" - the guys on this forum have posted everything you need to fix your RA.
Make sure transmission fluid is genuine Mitsu or Redline. This affects dog/gear engagement when shifting, big time.
The only time you would replace your clutch is when it is slipping - slip is real obvious to a driver. This doesn't seem to be your problem.
Old Jun 11, 2017 | 05:32 PM
4G63_EVO's Avatar
I didnt realize he had a RA and was only mentioning the civic because it was a failed CMC
Old Jul 17, 2017 | 07:22 PM
BStalzer12's Avatar
stock CMC isnt the greatest so it could very well be that
Old Jul 22, 2017 | 09:30 AM
RalliartN's Avatar
Stock CMC fails only when the stock clutch pack has been replaced with one that has greater spring pressure to handle higher horsepower.
Tim2s3
Apr 24, 2009 05:14 AM
05EvoVIII
29
Apr 20, 2008 12:46 PM
ohthree
Jan 14, 2007 07:06 PM
Gruppe-S
Jan 12, 2007 04:11 PM
Go_Lancer_Go
Lancer Tranny/Drivetrain Tech
17
Jul 23, 2005 07:09 PM
