Parking Brake Adjustments?
Old May 15, 2018 | 09:56 AM
r5obiwan's Avatar
the parking brake on my 06 Lancer RA has had it's fair share of handbrake turns thanks to previous owners (mind you I would have done this myself at some point) and i noticed that there is a lot of slack in the cable, is there any way to tighten it sufficiently? the car is currently on blocks so the brakes are accessible right now.
Old May 15, 2018 | 11:30 AM
jingalalahoe's Avatar
There is an adjuster behind the hub in the circled area. Turn it by couple of turns and you'll see the shoes move apart, that makes the cable tighter.
Make sure you tighten the slack evenly between the two rear wheels.
Old May 16, 2018 | 05:37 PM
r5obiwan's Avatar
thank you, i was having issues trying to figure out where to tighten it as there is a small adjustment I could make at the parking brake lever itself but that didn't make much of a difference.
BEKevo
Jun 15, 2013 07:55 AM
tiggeryellow1
Apr 16, 2011 01:13 PM
DaWorstPlaya
Oct 21, 2008 09:47 AM
JoCCe
19
May 12, 2003 03:24 PM
