Intakes
Old Jul 5, 2004 | 09:49 PM
AdamRA's Avatar
Originally Posted by Jesse00
RRM one is the one to go for simple and clean assembling. One piece is better because there less part to fit together which means less part you can mess up. Go RRM~
I chose Injen due to the second mounting point on the cold air piece.
Nothing is worse than having an intake bounce around making noise it's bad enough our suspension already does that.
Old Jul 5, 2004 | 09:55 PM
Deltarider99's Avatar
very true..
Do we know that the one mounting point of the RRM leads to it bouncing, or is it secure enough?
Old Jul 7, 2004 | 12:23 AM
MitsuJoe's Avatar
why does everybody complain about the hydrolock when for like $50 you can get the AEM bypass valve and install it inline with your CAI and never worry about it again!
Old Jul 7, 2004 | 03:32 AM
Jesse00's Avatar
because people cant think of that way to prevent hydrolocking??
Old Jul 7, 2004 | 01:43 PM
redralli04's Avatar
does that bypass really work? someone that has it please respond!! also i heard you need a two piece intake for the bypass, anyone know if this is true?
Old Jul 7, 2004 | 02:14 PM
the bypass is proven. A few of my buddies' engines have been saved because of them.
Yes, you do need a two piece, just so there's easy access to the valve.
Old Jul 7, 2004 | 02:53 PM
Freddie1111's Avatar
I've seen a demo set up by C & D (or motortrend, I forget) where they took an acura nsx and fully submerged the intake in a fish tank (the intake was longer and see-through for purposes of the demonstration) and you could see as soon as the filter tried to suck in water, the bypass valve opened and stopped the water from being ingested. A fairly simple device, but amazing when you see it work.
Old Jul 7, 2004 | 05:39 PM
fareastkorean's Avatar
i would go with the rrm, u can make it a short ram intake by jus using the top portion of the piping. I had my cai for about 4 months now and I had no problems with sucking up water and etc. I dont even use those gay bypass valve's they are useless, i mean if you submerge your car into water, that little sponge aint gonna do crap. Its a waste of 50 bucks plus it makes the cold air turn hot so u might even lose performance. But yea go for the rrm, it rains here in VA all the time and it pours, i always drive safely around the water and never hydrolocked my car yet!
Old Jul 7, 2004 | 09:37 PM
rustyj84's Avatar
RRM all the way
Old Jul 7, 2004 | 11:28 PM
MitsuJoe's Avatar
yes you would have to cut your intake at some plact to make this work and yes the bypass actually works. Sport Compact Car tested it a couple of years ago and the engine ran fine when the intake filter was submerged in a fish tank full of water. Of course the car bogged right down and almost died, but not one drop of water made it into the engine!
Old Jul 8, 2004 | 09:30 AM
Sorry, it WAS Sport Compact, not C & D or motortrend.
Old Jul 8, 2004 | 10:55 AM
just make sure if u do go and buy a bypass valve, get one made specifically for your intake. I think aem only makes bypass valve's, but i dont think itll fit on the rrm unless u do some cutting like that guy said
norlanrodriguez
Dec 22, 2011 11:03 AM
screamthepoetry
Feb 6, 2011 10:42 PM
joberk3
Lancer Engine Tech
12
Jan 22, 2006 01:35 PM
browntriniboy
Canadian Forum
Sep 18, 2004 11:36 PM
Gas'd LanOZ
Dec 2, 2003 04:31 PM
