6 Cd Changer Adapter?
I have the new 05 ralliart and it came with the 6 Cd Changer. I had replace the head unit and the plug for the 6 cd changer does not fit the new head unit. Is there an adapter i could get to use my aftermarket head unit and use my stock 6 cd changer?????
I dont think so, you may wanna check www.soundgate.com though.
Check with the Mitsu dealership to see if they can recommend anything. As well, you may want to check out a local car audio shop to see what they have available.
99% of the time advice is free. Ask around!
Since Soungate doesn't seem to offer anything and AFAIK most aftermarket decks work only with like-branded changes, you're probably SOL
I think options like 6 CD changers are risky to get stock if you plan on upgrading your sound system much.
Btw, have you had any problem getting bass out of your stock subwoofer since you swapped your head unit? I assume you used the Soundgate adapter to hook your new HU up to your stock amp.
I think options like 6 CD changers are risky to get stock if you plan on upgrading your sound system much.Btw, have you had any problem getting bass out of your stock subwoofer since you swapped your head unit? I assume you used the Soundgate adapter to hook your new HU up to your stock amp.
hi i have the same car with a 6 cd changer too i also wanted to swap the headunit and havnt been able to but i left that alone and now i dont know how to wire a sound system into that car i just got to rocksford fosgate 12s and i want to hook themup but idk wat to do??? take out the stock 8in sub and rewire??? anybody know?
Lancermann
Dec 16, 2015 11:25 AM
S6devil
For Sale - Miscellaneous Automotive
Sep 11, 2010 09:44 AM
imajinmyfx
Apr 12, 2008 07:13 AM
brandonchino
Jul 9, 2005 07:43 PM
