how can i install a oil gauge on lancer ralliart 2006??
how can i install a oil gauge on lancer ralliart 2006?? the gauge only has cables red,black,orange and green...would like your help
sounds like an electric oil gauge. the gauge should have a (+), (-) and a (s) on the back next to each male spade (if it's like a VDO gauge) the fourth wire probably goes to the light. Red is 12v switch power (fuse box), green is ground, black is probably sender and orange is probably light.
post up a pic
post up a pic
At the back of the engine block you have your oil sensor for your oem cluster light. Two choice: remove the oem sensor and put the sensor in the kit. You got cell in the cluster, just remove the bulb. Second choice find a T adapter for plug your stock sensor and your gauge sensor.
Red and black is the + -
White is the on off swicht put this on ascesory wire.
You have to find a way for you sensor wire in the firewall, the best is in the passenger seat.
Be carefull the drive shaft is very close, it can easy cut the wire if you installation is not good.
Fix your connector correctly with good stuff, it's easy to have a vaccum and lost oil after fitting the sensor.
johnnycage
For Sale - Wheels / Tires / Suspension / Brakes
Dec 29, 2014 01:37 PM
