WIll this work!!?
Old Dec 8, 2008 | 01:57 PM
GiLizILL's Avatar
WIll this work!!?
http://www.vr-speed.com/store/greddy...8-9-p-376.html
and just get the routing option of recirculated into intake only.
you guys think thiswill werk and fit?
Old Dec 8, 2008 | 02:12 PM
Robevo RS's Avatar
yes it will, if you recirculate it.
I had it on my VIII, but its flatters too much.
Old Dec 8, 2008 | 03:05 PM
Bom's Evo's Avatar
It might flutter even more since the turbo is smaller and running less boost.
Old Dec 8, 2008 | 03:07 PM
Bom's Evo's Avatar
An intake will make your stock dv make noises for 1/3 of the cost of that. It'll make power too....
Old Dec 8, 2008 | 03:22 PM
GiLizILL's Avatar
thanks for the info..guess its a no go then.
Bom's EVO, will a drop in do? or a whole new intake system
Old Dec 8, 2008 | 03:25 PM
jester81783's Avatar
Ive got one if youre interested
Old Dec 8, 2008 | 09:53 PM
Bom's Evo's Avatar
From experience its has to be an open element to make noises. I don't think the drop in will do much in sound. Maybe the HKS one. I'm gonna do the first stage of mods soon. As soon as this ZChip is released or someone local can flash this car good.
I.E. If you open the air box the DV will make noises. The air box is sideways now though....hahaha. The airbox is there to keep the noise down, keep the air cleaner and keep the temps low.
Old Dec 8, 2008 | 09:57 PM
Bom's Evo's Avatar
Maybe you should try the full intake system.
I don't plan on removing the Airbox on this car though. Keeping it very very mild.
Old Dec 9, 2008 | 04:39 AM
lancerdave86's Avatar
Check out the BPV that Forge Motorsport makes
Old Dec 9, 2008 | 09:10 AM
ambystom01's Avatar
Stay away from the Greddy and the HKS, they're notorious for causing issues. If you want a better BPV, buy the metal Evo 9 one. If you want to make the stock BPV louder, you need to run more boost (meaning a tune), have a larger exhaust and an intake. The intake won't give you much power (if it gives you anything at all) but it'll make all noises that much more noticeable.
Old Dec 9, 2008 | 10:15 AM
http://www.forgemotorsport.com/conte...duct=FMDVSPLTR
Old Dec 9, 2008 | 10:52 AM
GiLizILL's Avatar
thanks for all the good info. so theres no aftermarket reliable BPV for our car?
Old Dec 9, 2008 | 11:32 AM
ambystom01's Avatar
Not unless you go to the Forge or APS units. Even then, the sound won't be that much louder, it's simply the nature of the beast. If you want the car to run 100% fine, you need to recirculate all the air which keeps the noise down. If you want sound, you need to vent some air to the atmosphere which makes the car run worse (potentially).
Old Dec 9, 2008 | 11:52 AM
GiLizILL's Avatar
so with the stock evo 9 mr BOV..its just an easy 10 min replacement and it will perform the same as the stock bpv?
Old Dec 9, 2008 | 11:55 AM
ambystom01's Avatar
Yeah, not sure if it's worth the money though.
