My Z-Chip Review
Please take your trolling posts elsewhere.
And many times happens, some one with the lower dyno numbers are actually faster on the real life then the higher ones.
That is why i said, for the newbies the Dyno numbers not salt and grain.
The dyno is a tool to measure the gain from your base number. On that particular dyno, thats all.
Prove me wrong on this.
it sounds like there's some crazy lag off the line. but from 40-70 that boost is really crankin'. sounds mean too!
a metering device would probably put it at 5.5 seconds to 60, pretty much in line with what reviewers are getting using torque brake method. which is pretty awesome. you don't have to break your tranny or eff up your brakes if you use a chip!
but it sounds like you'll have to live with the CELs.
I can't wait for my sportback!
If you flip the key to off and back on real quick, it resets the idle and if you do it 4 x it resets the code.
It is not limited to the Ralliarts as the rest of the Evo X family gets the code as well.
Even with other tuning methods the overboost code can come on periodically. We are working with the ECU code to try and find a way to disable the code altogether, but in the meantime its a temporary nuissance.
New graphs and numbers info added to this post!
https://www.evolutionm.net/forums/6528931-post2.html
I think the RA is fairly quick from about 10 MPH to about 70 MPH. After that it starts to run out of steam (boost). It hesistates slightly at takeoff but as soon as you can get to 3k RPM it will take off pretty nicely.
