Wheel Offset..
Old Jan 15, 2009 | 11:14 AM
GiLizILL's Avatar
Wheel Offset..
Ok what exactly is offset?
Im looking into buying some rims, and which offset whould I look for, that would work without spacers and what not.
example..
would these fit?
5x114.3
18X7.5j
et+42
thanks
Old Jan 15, 2009 | 11:25 AM
lancerdave86's Avatar
they should i would think i believe our stock offset is 45 so its not a big jump to go to 42
Old Jan 15, 2009 | 11:29 AM
Bom's Evo's Avatar
Those would fit fine even with 225/45/18 tires.
Is the Lancer GTS suspension the exact same as the Ralliart?
Is the only difference the shock and springs??
If that is true, then this info is correct from what I gathered from lancertuners and other lancer forums.
+50 the wheel sits in more.
+46 is stock.
+42 pushes the wheel out more.
+35 pushes the wheel out even more.
So if you lower the car too much you run the risk of rubbing on the fender because the wheel sits pass the fender.
If you got like a +48, the wheel sits in more compared to stock. So when you lower it, it'll be tucked looking.
I'm wondering if 18x8 +35 would fit.
I really don't want to goto a 225/40 tire. It'll throw the speedo off...
Evo's have it easy with that extra 2 inch wide fenders....They can fit any wheel and offset.
Old Jan 15, 2009 | 12:18 PM
Bom's Evo's Avatar
Well, I found this link.
http://www.bigcustomwheels.com/rt_specs.jsp
It says mines fits with no problem.
Old Jan 15, 2009 | 02:38 PM
aestival's Avatar
[deleted]
Old Jan 15, 2009 | 03:01 PM
heavyD's Avatar
Originally Posted by aestival
You've got that backwards -- here's a useful link with a diagram that explains it as quickly as anything:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
The original poster is very unlikely to have any issues with the wheel specs listed (except maybe for the centre bore -- needs to be big enough, and you'll almost certainly need some sort of spacer to install them properly), unless he tries to go with ridiculously wide wheels, of course. From everything I've read, he should be fine with 225's, but likely not 235's (with that +42 offset).
No he's right. Tirerack is talking about the hub position not the position of the wheel face as Bom's was talking about.
Old Jan 15, 2009 | 05:56 PM
aestival's Avatar
Sorry, you're right of course.
Old Jan 16, 2009 | 06:22 AM
Heliart's Avatar
stock Ralliart offset of 46mm
http://clubralliart.com/showthread.php?t=30
google up "offset calculator" and you'll find tons of website where you enter your stock offset, tires size, etc, then your desired new rims/tire size and it'll calculate your new offset
Old Jan 16, 2009 | 06:49 AM
Bom's Evo's Avatar
Just to help for a clearer understanding. Since your going .5" wider you got a lower offset from stock which pushes the wheel out more. The offset compensates for the extra width.
Old Jan 16, 2009 | 12:48 PM
ambystom01's Avatar
You would want a higher offset than stock if you went wider and wanted the wheel to sit just like stock.
Old Jan 16, 2009 | 02:07 PM
heavyD's Avatar
Yes but you can run the risk of the tire or wheel rubbing against the struts or the wheel spokes rubbing against the brake calipers plus using wider wheels/tires with higher than stock offset can end up 'tucked' looking which isn't normally desireable.
Old Jan 16, 2009 | 02:36 PM
ambystom01's Avatar
True but if you kept the same offset as stock, or lower, you'd run the risk of destroying the fender.
Old Jan 16, 2009 | 02:46 PM
heavyD's Avatar
Yep but that depends on if you are on stock or lowering springs. There are alot of variables in play which is why I always like to hear from people that have tried the various combinations for information on what works and what doesn't. Problem with newer cars is that there isn't alot of information available and you have to trust outfits like Tirerack that don't always test fit and go by dimensional specs only which doesn't always work. Case in point they list that a +48 mm offset fits Neon SRT-4's which is false. The rear will fit but the front will not because the wheel spokes will come into contact with the brake calipers. How do I know? Many of us learned the hard way lol.
Old Jan 16, 2009 | 03:31 PM
ambystom01's Avatar
Again true, it's just a matter of playing with the car to see what fits. Ralliart guys can look to the GTS for that which should make it easier.
Old Jan 16, 2009 | 05:47 PM
LuDa's Avatar
seen a kitted lancer GTS that had fenders rolled..had 245/40/18 tires on 18x9 wheels +32 offset really aggressive need to see if i can find it
