Wheel Offset..
Old Jan 23, 2009 | 10:01 PM
  #46
ambystom01's Avatar
A 7" rim with a 235 won't be a stretch, it'll be a squish. I have 17 x 7 stock and 17 x 8 for summer use with 235 tires and I can't imagine putting the 235s on my stockers, they're just too wide.
I just checked the Road and Track November issue and it lists the wheels as 18 x 7.5 with Bridgestone RE050As. Just looking at the rims though they appear stock.
Old Jan 28, 2009 | 11:53 AM
  #47
Bom's Evo's Avatar
I have my winter wheels on guys.
18x8 +35 rota torques bronze. These are EVO fitment i picked up for 4 Benjamins new!
Unfortunately I didn't mount the 235's just fear of it rubbing.
I put on 225's Continental ContiExtremeContact and let me tell you these tires rock in the winter. Everything fits good and rides nice. 1. These tires are 10x better in the winter than the stock summer yokos in the summer. Handling is also a lot more confident. The stock wheels just felt narrow. Now there is a slightly larger footprint.
I will be getting some 17's 8.5" forged wheels in the summer. Just gotta save up for that. $400 per wheel....instead of $400 a set....crazy. Maybe, I'll get evo 9 or x wheels.
Old Jan 28, 2009 | 11:55 AM
  #48
Bom's Evo's Avatar
Also if you lower my setup it would probably rub easily. Might need a +40 to +42 offset. Then, I don't know if you can put on a 8inch wheel. That +35 offset pushes the wheel far out.
Old Jan 28, 2009 | 12:06 PM
  #49
AJsGenerX's Avatar
If you roll the rear fenders, you may have a lot more options of wheel sizes and offsets. I run 18x 8.5 with a +40 offset. It sits right up against the fenders and even sticks farther out than the side skirts. It has a very aggressive stance and can fit 235/245 series rubber. PM me or Robispec if you have questions on how you can fit larger sizes than 225 or 8 inch wide rims.
Old Jan 28, 2009 | 12:23 PM
  #50
xdemoulasx's Avatar
how close was the fitment? if i dont lower right now will i still need to roll the rears to get the setup you have? i definitely want that setup but i'm a little bit nervous about rolling my own fenders on a car with just over 1000 miles on it haha.
Old Jan 28, 2009 | 02:53 PM
  #51
AJsGenerX's Avatar
Originally Posted by LuDa
not so much a stretch i know people who are running 8.5-9s on 235 tires...thats a stretch
235s Dunlop Direzzas are no stretch on a 8.5 inch wide rim.
Old Jan 28, 2009 | 03:04 PM
  #52
AJsGenerX's Avatar
The fitment was real close to the rolled rear fenders with my setup. Guaranteed it would not fit on stock fenders. Robispec also grinded away the inner part of my fenders to give me extra clearance. Also on this set up, with a +48 on a 8.5 inch wide wheel, you will not clear the front struts (Im on Megan Coilovers). I needed 8 mm spacers to clear. I also ran the 8 mm spacer in the rear for a more aggressive set up. So an originally +48mm offset 8.5 inch wide rim is now a +40 mm given the 8mm spacers.
Here's how it works (my understanding). The stock ralliart has a +46 mm offset and also a 7.0 inch wide wheel with 215 rubber. If you buy 8 inch wide wheels with a +46 offset, then your wheel will take up 0.5 inch on inner side and stick out 0.5 inches on the outer side. If you have an 8.5 inch wheel with a +40 offset, your wheel will take up 0.75 inches on the inner side and 0.75 inches on the outerside. But since you have a +40mm offset, your wheel will stick 6 mm more out from the stock wheels. I hope everyone can understand this. Without rolling your fenders, there's not many options. I believe CRC has a 18x8 +35mm wheel. His tires (235s) rubbed against the rear fenders when he had weight in the back (passengers) or hit a huge dip in the road.
Old Jan 28, 2009 | 03:57 PM
  #53
xdemoulasx's Avatar
ahh... ok. so i guess im looking at rolling the rears then... i see you can rent the tool online with a heat gun and everything. maybe i'll do that if it comes down to it.
Old Jan 29, 2009 | 11:08 AM
  #54
GiLizILL's Avatar
Currently looking at these Tires.
http://www.tirerack.com/tires/tires....peed_rating=(Y)
what would yall recommend?
Old Jan 29, 2009 | 11:44 AM
  #55
heavyD's Avatar
You are a brave man using those tires in the snow. I have Direzzas on my Deuce and they are nice and sticky.
Old Jan 29, 2009 | 12:15 PM
  #56
Bom's Evo's Avatar
Yeah, 225 tires even rub a little on big bumps in the rear. There isn't a lot of room in the rear. With the same 18x8 +35 setup. I believe cr22 has 235's.
Old Jan 29, 2009 | 09:41 PM
  #57
AJsGenerX's Avatar
hahaha...I don't actually. I had just put on the wheels and tires after I got them to take some pics. Also, my dd is a 2002 Lancer ES for the winter. My mother is enjoying her 6 week vacation while I get to use her car and store mine.
Old Apr 26, 2011 | 11:05 PM
  #58
Laza's Avatar
Getting back to an old topic, so is anyone running +42 offset 18x8 rims on an RA? I'm considering that setup myself, as 48 offset sounds way too high :-(
Old Apr 27, 2011 | 06:04 AM
  #59
initial_d2k's Avatar
+42 x8 sounds perfect .. just go for it
Roen
Apr 10, 2014 10:56 AM
Ofcbanks
Jan 29, 2014 01:35 PM
thatevo8
Nov 17, 2013 10:54 AM
rubio2325
26
Apr 26, 2012 06:08 PM
thatguy5
Nov 1, 2011 08:18 PM
