Manual Shift..
Old Feb 2, 2009 | 03:15 PM
lookitznite's Avatar
Manual Shift..
So guys Just curious..when you guys throw it in manual...what RPM do you guys shift at... i nromally go around 4500....
Old Feb 2, 2009 | 03:19 PM
nawaz's Avatar
around 7,000 rpm....hehehehaha
Old Feb 2, 2009 | 03:21 PM
krnkimchi702's Avatar
redline....
i usually shift around 3500-4000
Old Feb 2, 2009 | 03:46 PM
wow redline? oh my god... isn't that a little bad for the tranny bro? i thought i was bad at 4500...i just want this car to last is all...
Old Feb 2, 2009 | 06:04 PM
laksman91's Avatar
depends on how often you redline I guess
Old Feb 2, 2009 | 06:34 PM
jRox's Avatar
< 3000 rpm
Old Feb 2, 2009 | 07:07 PM
GiLizILL's Avatar
normal- 3-4
fast days-4.5-5.5
Old Feb 2, 2009 | 07:15 PM
You guys think in the the later you shift has an affect with the longevity of the tranny?
Old Feb 2, 2009 | 07:26 PM
hibby's Avatar
Why bother having 7,000 RPM if you're not gonna use 'em?
Old Feb 2, 2009 | 07:58 PM
Runaround's Avatar
Nah, I have never had a tranny that died from using the designed RPM range (and yes I have killed a transmission before). I used to redline my s2000 pretty much ever time I drove it, and it redlined at 9,000 RPM. The killer of transmissions is Torque.
Old Feb 2, 2009 | 08:05 PM
dboz's Avatar
Also, not much reason to mod!!
Old Feb 2, 2009 | 08:12 PM
ambystom01's Avatar
That's not entirely true, torque moment is what kills transmission. You can get a lot of force acting on a transmission in a very short amount of time if you treat it too aggressively. This is why you don't redline shift a car constantly.
Old Feb 2, 2009 | 09:04 PM
Euripides's Avatar
The tranny shoudl be able to handle the redline, but not if its excessive, and overdone..Even when you switch it to sportmode, and let the tanny do the shifting, If your at a dead stop and floor it, or downshifted to 1st gear and gun it, it will hit the rev limiter a couple of times them shift..Its nothing new, its what it does..just dont bang it off the rev limiter manually like a idiot all the time and your fine
Old Feb 2, 2009 | 09:07 PM
ambystom01's Avatar
The tranny should be able to handle hitting the rev limiter (or rather shifting at the rev limiter) but it's not a good thing to do all the time. Every once in a while is fine but like anything, the more you abuse it, the higher the chance of something going wrong.
Old Feb 2, 2009 | 09:12 PM
Euripides's Avatar
One thing that i thought with the Ralliart without the S-sport mode, it wasnt capable to constantly hit the rev limiter until you shift, I personally thought that it would shift for you..besides the launch control capability in the MR whats the diff between sport and S-sport?
more responsive?
