AMS Project Lancer Ralliart
This is considered our 'Stage 1'
The next stage will include a fmic, upper pipe, and some other goodies we will figure out when we are through testing. Maybe the intake/small battery, lower pipe, etc.
For anyone who can't be without their ECU in their car for a day or two and doesn't have a laptop or a cable, I have a solution for you. Please give us a call or send me an email.
For anyone who does have a laptop and a cable, I will be happy to email you the correct calibration for your car. Please just give us a call or send me an email to get the process started.
Question, seeing as my car is 4 days old and about 80 miles used, is it safe to re-flash seeing as i'm not done with the famous "brake-in" procedure. Or there's nothing to worry about with that, is it?
I wanna get the re-flash asap, but i also havea second ?
i dont know if i miss it cuz i think u said it earlier, but say i later get the fmic, ic pipes and intake, a re-flash might be due, how much would that be? another 500 bucks?
thankz 4 ur support
Chris@AMS:
Trying to get one of these (Ralliart) as we speak. I have, and use, EvoScan for datalogging on the Eclipse and was hoping to be able, when and if I get a Ralliart, to use EvoScan on the Ralliart to do a couple logs and than send them to you to get a tune (through emailing as I cannot be down a day). Would/does EvoScan work for the Ralliarts or would I just have to get a basic "mail-in" tune?
I thought I would post this up just in case anyone was wondering if EvoScan can datalog on the Ralliarts.
Thanks for your time.
yes yes! that's exactly what I want!
thankz 4 ur support
thankz 4 ur support
Re-flashes and re-tunes are $200
Chris@AMS:
In the mean time you can get our 'base flash' and I'd be happy to make any tweaks you need later down the road when we have an adequate logging solution.
-Chris
Evoscan does not work on these yet. There is a logger called PCMscan that some are using on the EVOX. It does not log the parameters that I find necessary for a correct tune.
-Chris
-Chris
