Launch Control for the RA
Old Mar 26, 2009 | 08:02 AM
ambystom01's Avatar
No.
Old Mar 26, 2009 | 08:50 AM
madcows's Avatar
Even if "neutral slamming" did work, you have little to be worried about if you did this at a low RPM. Also, it won't cost you anything since you still have a warranty.
At any rate, neutral slamming, dumping the clutch, etc., isn't good on any car. Even on race cars transmissions that cost more than your entire car.
Old Mar 26, 2009 | 08:56 AM
ambystom01's Avatar
Until they find out you've been neutral slamming and they deny you coverage. You're better off just power-braking, if it's at low RPMs, it'll likely have the same effect.
Old Mar 26, 2009 | 09:01 AM
japan101's Avatar
The GTR launch control was not stripped from the car it was updated to include the VDC being on and therefore it is now better and within warranty limits to use on the car. The software update is open to all current GTR owners as well as the new 2010 models. The software update also lowers rpm's on the launch so it will harm the transmission less if at all.
I just want the Super Sport mode the Evo X MR has.
Old Mar 26, 2009 | 09:07 AM
ambystom01's Avatar
I thought the GTR lost launch control altogether.
http://jalopnik.com/5094212/2010-nis...launch-control
http://www.autoblog.com/2008/11/20/n...rom-2010-gt-r/
Old Mar 26, 2009 | 09:49 AM
madcows's Avatar
Deny everything if they ask. heh. At any rate, there's a very good chance that the ecm/tcu doesn't allow for neutral slamming anyways. Also, a neutral slam will give you a harder launch than power-braking, but of course, not only will it cook the clutch, but depending on how hard the launch is, shock the drivetrain. Still, if it's available on the MR and doesn't kill the trans, then it shouldn't have any problem on the R/A with less power.
SuperSport mode is where it's at.
Old Mar 26, 2009 | 09:51 AM
ambystom01's Avatar
And that's why people with legitimate problems can't get warranty service.
Old Mar 26, 2009 | 01:59 PM
japan101's Avatar
^ Here is what I read on the GTR launch control.
http://www.gtrblog.com/2009/02/03/ni...0-demystified/
Old Mar 26, 2009 | 02:02 PM
ambystom01's Avatar
Strange, it seems to contradict the above two links.
Old Mar 26, 2009 | 02:16 PM
japan101's Avatar
Its a Nissan, the car contradicts physics. GTRblog.com always has the latest news on the GTR. All of it is credible.
Old Mar 26, 2009 | 02:22 PM
XxLaNcErGTSxX's Avatar
The GTR has launch control but it voids the warranty. The RA does not have launch control. The Evo X MR does have launch control when it's in S Sports mode something the RA does not have. Launch control would be a cool feature though
Old Mar 26, 2009 | 02:28 PM
japan101's Avatar
^ The GTR has updated software so that it can use the VDC while it's on and still have launch control.
dfarmer0033
May 18, 2017 08:43 AM
Evoguy!123
Nov 27, 2016 05:14 AM
silex
Dec 4, 2008 03:55 PM
AirNKAir5
May 5, 2007 01:01 PM
Arithmetic
Driving Techniques
Dec 8, 2004 09:58 PM
