Radiator Fan stays on when car is off
Old Aug 26, 2009 | 05:52 AM
Nismo2k6's Avatar
I have a 2009 Ralliart and the radiator fan stays on when I turn off the car. I tried to wait to see if it will turn off on its own, but after 5 minutes, I get impatient so I turn the car back on and then turn it off and then the fan turns off.
It doesn't happen all the time, maybe like once a week.
I called the dealer and the service rep said that sometimes the fan will stay on after the car has been turned off so that the engine will cool. I don't remember reading anything in the owners manual that this was a feature of the car.
Has anyone else experienced this?
Old Aug 26, 2009 | 06:15 AM
velocityhead's Avatar
Perfectly normal. Tends to happen more after a long drive on a hot day.
Old Aug 26, 2009 | 06:16 AM
bryanole27's Avatar
Normal...let it do it's thing.
Old Aug 26, 2009 | 06:22 AM
DatRAzn's Avatar
Don't do that.
It's part of the cooling system for the car. If you want it to go away quicker, open the hood and let it sit.
From a previous thread that this was brought up in:
Originally Posted by Ladogaboy
It is very normal. I forget the exact physics and thermodynamics behind it, but in essence, whenever you drive a car, stop it, then drive it again for a very short distance and then stop it again, the engine coolant heats up in a way the car has to compensate for.
Think about it this way, you've just driven at 60 mph for an hour. Sure the car is producing a lot of heat, but there is a massive amount of airflow over the radiator. Now your car sits, all of the heat from the engine doesn't just disappear. Now, you start up the car after a very short period of time (the engine is still much hotter than when it was initially started), drive it a short distance, and there is almost no airflow over the radiator. The car senses this and engages the radiator fans in order to create airflow and dissipate the heat.
Old Aug 26, 2009 | 07:08 AM
majinfajita's Avatar
Also, not to be snide but the answer was in the manual.
Things like this, the gear indicator blinking, etc. were all detailed in there.
Old Aug 26, 2009 | 07:25 AM
JONralli09's Avatar
you dont need tp turn on and off the car or even lift the hood. just TURN OFF THE A/C. thats all, turn off the A/C before you turn off the car. And it is in the manual
Old Aug 26, 2009 | 07:29 AM
akj237's Avatar
As everyone else has already stated, this is perfectly normal.
Old Aug 26, 2009 | 08:10 AM
Bom's Evo's Avatar
It's kind of like your stock turbo timer.
Old Aug 26, 2009 | 08:49 AM
JONralli09's Avatar
not really, turbo timers keep the car running to allow the oil to cool down..this is just an electrical fan that stays on. The car isnt running..
Old Aug 26, 2009 | 09:49 AM
Bom's Evo's Avatar
Oh yeah, the oil.
Well, it cools the radiator which in turns cooling the coolant that runs through the turbo.
I still think you need real air circulation for it to really cool. I don't understand why leaving the motor running cools things without any circulation.
Old Aug 26, 2009 | 10:31 AM
JONralli09's Avatar
when the motor was just running through the RPMs when you drive which raises the temp of the oil, letting the car idle for 2 min does cool down the motor even with out air circulation because the oil itself is circulating.
Old Aug 26, 2009 | 01:16 PM
JCGator42's Avatar
^ yep I have noticed this, only once in a while and it's normal. I never turn the a/c off (hot *** florida).
Old Aug 26, 2009 | 05:11 PM
Tommy Di Cat's Avatar
Originally Posted by JCGator42
^ yep I have noticed this, only once in a while and it's normal. I never turn the a/c off (hot as$ florida).
I bet you can't wait for cooler temps too. Boosting in sub 60 degree temps rule
Old Aug 26, 2009 | 06:01 PM
JCGator42's Avatar
i wish .
...I noticed this happening pretty much every time I stopped the car today, this is in 90*+ FL weather
Old Aug 26, 2009 | 06:27 PM
08Lancer89's Avatar
Yep it's hot as hell down here
TURBO_S2K
Jun 3, 2025 12:10 AM
TuJay
May 2, 2017 06:49 PM
MrHouse
Jun 25, 2014 02:32 PM
nile13
Lancer Troubleshooting
Jul 31, 2013 12:14 PM
evo12345
AEM EMS
Sep 27, 2006 03:34 PM
