AEM EMS Get tuning help for your AEM EMS system.
Aem ems radiator fan won't shut off ?
Old Sep 17, 2006 | 09:17 PM
evo12345's Avatar
Question Aem ems radiator fan won't shut off ?
I have a aem ems and when I turn off the car the after market fan thats in front of the radiator won't shut off. I have to disconnect the battery so my car won't die. Once I put the negative back on the fan just starts going. I called a local shop and they told me its the aem and that I should send it in. I really don't want the down time. Has this happened to anyone else?
Thanks
Old Sep 17, 2006 | 10:14 PM
jbrown's Avatar
It's a simple fix, if I could remember what it was I would tell you. do a search on the AEM forums.
search here:
http://forum.aempower.com/forum/index.php?action=search
Mitsu / Evo forum:
http://forum.aempower.com/forum/index.php?board=49.0
Old Sep 18, 2006 | 03:07 PM
DarksideEng's Avatar
If I remember correctly, theres a rad fan option somewhere, I just looked but couldnt find it, I remember seeing it though.
Old Sep 18, 2006 | 07:24 PM
Ackerson's Avatar
Go to Options:Configure Outputs. Select LS9 from the pulldown menu labeled "Outputs" and go over the parameters to determine what needs to be changed.
Old Sep 20, 2006 | 11:25 AM
GTVEVO's Avatar
I helped troubleshoot this problem on a car reciently and we found out that one of the fan relays was toasted, you can check the relays in the fuse/relay box under the hood by the battery. If it worked before on your AEM and doesn't now this very well could be your issue.
On our problem it acted like the high and low speed was inverted.
Just a thought.
Old Sep 27, 2006 | 03:34 PM
evo12345's Avatar
Thanks
TURBO_S2K
Jun 3, 2025 12:10 AM
crisdiarata
AEM EMS
13
May 3, 2015 06:20 AM
foxbear2277
Aug 16, 2012 05:09 PM
crisdiarata
AEM EMS
11
Sep 21, 2011 12:04 PM
jacofiero
Jul 24, 2009 01:08 PM
