Cracked front chrome ring
Old Apr 13, 2010 | 02:58 PM
T67@20ART's Avatar
Someone just backed into my car and took off couldn't get the plates, any ideas on how to fix my broken chrome ring, I was just about to plasti dip it but since it's broken should I get a new piece....
Old Apr 13, 2010 | 03:49 PM
Euripides's Avatar
That stupid piece is expensive!, bc the chrome was peeling off of mine, and i got warranty on it, but i looked at the price, and it was like at least a couple of hundred bucks for it, I think, bc that may of included the labor
Old Apr 13, 2010 | 04:40 PM
RotorGlow's Avatar
Us Edmontonians sure like to claim warranty
I guess our weather is too hostile for the lil Ralliart
Old Apr 13, 2010 | 05:36 PM
athmak15's Avatar
Fix it with some fiberglass. A rock hit mine and cracked it. Did a little bit of fiberglassing and painted it, looked good as new!
Old Apr 13, 2010 | 06:00 PM
T67@20ART's Avatar
Well thanx for the replies I guess I'll try superglue, duct tape and a permanent marker for that extra jdm look. Man I'm starting to stress out, first I get rear ended causing $1500+ in damages then small rock chips, oil change every 1.5 months cuz I drive so much and now front end damage. Guess it's time to buy a beater
Old Apr 14, 2010 | 11:40 PM
evil03's Avatar
speaking about the nose ring... did you guys know there are 2 versions?? 1 is solid full ring and other is a 2 piece ring...
Old Apr 15, 2010 | 12:19 AM
tjac357's Avatar
Yea I was in an accident and had mine replaced. I started with 1 piece, now I have 2 pieces. It was driving me crazy, but since I plasti dipped the ring it is harder to tell.
Old Apr 15, 2010 | 02:21 AM
markguutz's Avatar
does anyone know the part number for the chrome ring? Need to replace mine
Old Apr 16, 2010 | 10:46 AM
jscout21's Avatar
Gray $277.35 PN 7450A359
Chrome $ 393.72 PN oops I thought I wrote it down. If your just going to plasti dip then I would order Gray. save some $$ unless you want the option to go back chrome.
Old Apr 16, 2010 | 11:07 AM
markguutz's Avatar
o my goodness you werent joking when you said it was pricey! is the gray just a primer or something?
Old Apr 17, 2010 | 07:24 AM
jscout21's Avatar
Not sure it its primer or colored to match a car or something. I used JB Weld epoxy and put it back
together and then sanded it down with 400 grit sandpaper and primered and painted flat black. I tried plastidip but it only peeled off after the first wash and that was with 4 coats. Good luck.
Old Apr 17, 2010 | 10:31 PM
gccruz's Avatar
you must have not cleaned it or applied it well. Plasti dip works great. I have done mine twice. but only cuz i got into an accident and cracked my ring. It lasted 9mo thru winter without any problems. Then my bodyshop painted the new one black like how i had it, but it peeled in a month. so i plasti dipped it an it. And mine is now 2 piece.
Old Apr 18, 2010 | 08:28 AM
jscout21's Avatar
Im pretty sure I did. I de-greased, cleaned and dried it and applied 4 even coats and about 24 hrs of drying time. I hand washed the next day just for it to peel off. Maybe I just have that luck or a bad can who knows. I just sanded and painted and has worked out great for me so far. I encourage anyone to try what works for you and if plastidip is the way then rock on. I did plastidip a strip in my top airvent and it has stood up wonderful and cant complain.
Good Luck
evozoom
17
Aug 20, 2017 05:19 PM
Stevo9267
Feb 23, 2016 09:22 AM
Accursed
Jun 2, 2014 04:00 PM
1998_GSX
Mar 7, 2013 07:46 AM
solskimmer
08+ Lancer Show / Shine
Feb 8, 2013 06:06 PM
