Question to RA Modifiers
Old Jan 11, 2011 | 05:17 AM
  #31
CFMP RAblue's Avatar
Originally Posted by YawnY
It's not that easy! Some of the warranty parts, more for EVO's and RA's get sent right back to Mitsubishi in Japan.
Hey i am also in winnipeg, which dealer u at and we should meet up... when i get my car back... it was in an accident mid SEPT!!! 2010!!! and i still dont have it i guess shipping from japan takes a while when theres 15k of damage...canadian
Old Jan 11, 2011 | 06:00 AM
  #32
Krisko's Avatar
So is a tranny cooler good enough to push 350wtq
Old Jan 11, 2011 | 06:10 AM
  #33
jkennedy293's Avatar
Its not a overheating issue that limits the SST, its the mechanical properties of the clutch plates. The only way to fix this is to replace them with heavier-duty units.
Old Jan 11, 2011 | 06:24 AM
  #34
Krisko's Avatar
Can you give me a link to some
Old Jan 11, 2011 | 06:29 AM
  #35
Ghost1t's Avatar
I'm a Mitsubishi Technician, been with them for a couple of months...(yes I have access to all the service information, and I get deals on parts )
Hook a brother up, lol
Old Jan 11, 2011 | 06:39 AM
  #36
^correct however a cooler will help the stock packs last a bit longer under heavy use and its a bit cheaper then doin the packs.
Old Jan 11, 2011 | 07:16 AM
  #37
Google "South Side Performance"
Old Jan 12, 2011 | 06:18 AM
  #38
AntiBlitz's Avatar
Originally Posted by SharkyPR
False we have the same 1,2,3,4 gear ratios including the same Final Drive as the EVO MR.
Our Ratios in 5 and 6 are lower.
MR Gear Ratio:
1st 3.655
2nd 2.368
3rd 1.754
4th 1.322
5th 1.008
6th 0.775
RA Gear Ratio:
1st 3.655
2nd 2.368
3rd 1.754
4th 1.322
5th 0.98
6th 0.73
i correct my statement its a throttle limit in first gear which lets us wot our first gear unlike the MR giving us a stronger power thru first gear
https://www.evolutionm.net/forums/ev...-mr-vs-ra.html
