Very cold start, running rough.
Old Jan 16, 2012 | 08:59 PM
zebra4's Avatar
I started my car this afternoon to go to work and the tempurature was at -38 C (-36 F). I forgot to plug it in the day before. It started after turning over 3 times, but sounded like it was running on only 2 cylinders. Also, the throttle did nothing, it would not work. The RPM's went from 0-250 on the gauge but the cars idle was not changing. After about 30 seconds it started running normally again. My question is if anyone knows whether that is a cold start feature or something along those lines. I do not have my manual to look at. I just want to know if its supposed to do that. Thanks
Old Jan 17, 2012 | 08:28 AM
Mu-Meson's Avatar
I think this happened to me this morning too. -30°C (plus wind chill) and when it started, it sounded awful. I turned it back off, and tried again. Then it started and sounded about as good as it could at that temperature. Boy, do I need to build a garage.
Old Jan 17, 2012 | 04:37 PM
zebra4's Avatar
I tired turning my off and on again but it did the same thing. Oh well! Not much you can do
Old Jan 17, 2012 | 07:34 PM
xi's Avatar
xi
Ya it makes noise when flippin cold. Are you using 0w instead of the default 5w? Might help...
Old Jan 18, 2012 | 06:41 PM
zebra4's Avatar
No im running 5w-30 full synthetic... i might have to try a 0w-30
Old Jan 18, 2012 | 07:26 PM
xi's Avatar
xi
The manual says use 0w when it's gonna be below 0F (or something like that). You're WELL below that and even though 5 points isn't much, the motor needs all the help it can get!
Old Jan 20, 2012 | 07:36 AM
crak's Avatar
has anyone tried to install a block heater or something to keep the lines warm?
Old Jan 20, 2012 | 08:07 AM
Slyy's Avatar
by the sounds of it, you guys need a block heater for sure...
Old Jan 20, 2012 | 08:16 AM
snow's Avatar
Mine came with a block heather. I haven't used it though.... I have a garage at home and no power outlet at work!
Old Jan 20, 2012 | 08:17 AM
snow's Avatar
Derp! That would be a block heater, not heather...
Old Jan 20, 2012 | 08:25 AM
Sideshow's Avatar
I use a block heater every night during the winter (Northern Ontario) and use 0w-30 and it starts like a charm every morning. Heater fires up within a minute. Definitely wouldn't go without a block heater. I think it was like a $150 - $200 add on when I bought the car.
Old Jan 20, 2012 | 05:55 PM
zebra4's Avatar
I have a block heater, i just forgot to plug it in over the weekend when its plugged in she starts like a champ.
