Is this too much shaft play?
Old Feb 27, 2012 | 08:35 PM
Snipingdude's Avatar
The compressor wheel does not hit the walls. The noise you hear seems to be the residual oil inside the centerpiece. But I just wanted a general consensus from everyone. If it is too much ill just send it into FP for a green upgrade anyway.
thanks guys.
Edit: I read that because there is no oil in the turbo as of now that a small portion of this play would disappear once it is installed and oil is flowing through it once again. And that there must be at least a very small minimum amount of axial play (.5-1.5mm) to allow the oil film to seep in. Correct me if Im wrong.
http://www.youtube.com/watch?v=b51nbr4sPUs
Old Feb 27, 2012 | 09:14 PM
omegis's Avatar
Looks fine
Similar post:
https://www.evolutionm.net/forums/9911507-post106.html
sstevojr's Avatar
I don't think so, seems to be just a JB. But maybe some who has played with more than 4 can chime in....
Old Feb 28, 2012 | 07:49 AM
thanks guys..I just wanna make sure its normal play before i do the swap as well...
Old Feb 28, 2012 | 04:08 PM
turbotaloon95's Avatar
its hard to really tell from that video, but it seems ok. i would pay attention to the tips of the fins. if they look discolored like they were knicking the wall of the housing, then its rebuild time. actually a better tell would be marks on the housing wall. but yes the turbo is designed to have some some shaft play. ill come by one day to take a look in person.
Old Feb 28, 2012 | 07:13 PM
nunyas's Avatar
i feel this is whole thread is a setup for a twss comment...
I must get it out of my system...
TWSS
there
ok
i feel better now
tsidrift1
Jul 28, 2015 08:57 AM
fast03evo
Jun 14, 2015 05:33 PM
GgreyEVOIX
Nov 20, 2006 04:31 PM
ItalianEvo
Feb 11, 2006 02:41 PM
