Bought Used. Whats this?
Old May 28, 2012 | 06:33 PM
xShutYourMouthx's Avatar
Question Bought Used. Whats this?
Ok I bought my 09 ralliart used. I have found a few things Im unsure of. Also lots of loose bolts and just odd pieces. Any way was wondering if this was a Evo X turbo swap? Also anyone know the manufacture of this alarm?
Attached Thumbnails Bought Used. Whats this?-xshutyourmouthx-albums-my-ralliart-picture30822-img-20120521-182222.jpg   Bought Used. Whats this?-xshutyourmouthx-albums-my-ralliart-picture30819-img-20120521-182133.jpg   Bought Used. Whats this?-xshutyourmouthx-albums-my-ralliart-picture30900-img-20120302-160852.jpg   Bought Used. Whats this?-xshutyourmouthx-albums-my-ralliart-picture30899-img-20120302-160713.jpg
Old May 28, 2012 | 06:41 PM
Tiresomejunk's Avatar
Yes it is an Evo X turbo swap. The last picture of that black box is a really bad picture and cant make it out.
Old May 28, 2012 | 06:46 PM
I was 90% sure it was a swap. Ty
Left the fuzzy pic due to the coding numbers being on back of the module but the model is 765100 0202.
I found one on a search for sale on ebay refered to as a factory installed on a honda.
Old May 28, 2012 | 07:50 PM
Anyone feel free if they have question on there newly purchased used rides. This is meant to be a open post to help everyone.
Old May 29, 2012 | 06:05 AM
carbonair's Avatar
from the last pic it looks exactly like an aftermarket alarm system.
Old May 29, 2012 | 08:28 AM
Struc's Avatar
Get a heat shield on that exhaust manifold!!
Old May 29, 2012 | 10:56 AM
Heatshield was only off for pictures good thing to cause one of the flange bolts had backed out. Was getting Turbo pop turns out it Was from the loose flange bolt. Seen the carbon on the heat shield. E
Old May 29, 2012 | 10:58 AM
Yea just not sure who makes it.
Old May 31, 2012 | 08:28 AM
ande1234's Avatar
after market alarm
Old May 31, 2012 | 10:31 AM
RazorLab's Avatar
I'd make sure you have a proper tune on it for the X swap
Old May 31, 2012 | 03:39 PM
Yea hoping to be getting a tactrix cable soon. Everything seems smooth except 2-3 gear at times. Peak PSI seems to be around 22-23 PSI normal range is around 15-18 PSI. Just wish I knew the full story behind this car. Ive been going through it the last two months fixing issues. Leaking trans cooler crap inline filter. Fan not hooked up. Air intake was loose. Loose bolts ect. Iam just about to the point where I can get to back to building on it. Just wanted to make sure everything else is sound first. Futer plans Tactrix cable. boost pill exhaust, X MR LICP, waste gate actuator and 3 port,. Then possibly a big trans pan and brake kit.
waynep
Automotosports - Illinois
Mar 13, 2010 01:36 PM
EvoXcrzy08
Mar 5, 2010 10:20 PM
RUN99
12
Jan 4, 2010 12:44 PM
03redtype-s
Oct 29, 2006 09:09 PM
RealVibes.net
Nov 12, 2004 02:22 PM
