Cheapest way for 250whp?
Old Oct 7, 2012 | 06:43 PM
jlog1506's Avatar
Im looking for around 250-270whp on a budget. How would this be accomplished. Also I'm in need of better brakes. What would you guys recommend. Ik I've read all the stickies but still confused on what to buy. Thanks
Old Oct 7, 2012 | 07:39 PM
Steven_Trujillo's Avatar
A tune and some cheap bolt ons (exhaust, boost pill, and a drop in filter) that should do the trick.
Old Oct 7, 2012 | 08:00 PM
richardjh's Avatar
Best bang-for-your-buck in the torque/power department...
1. Buy a Tactrix OpenPort 2.0 unit.
2. Buy a boostpill.
3. Flash razorlab's free Base Map using EcuFlash.
4. Fit the boostpill.
5. ???
6. Profit!
Brakes are harder. The front factory rotors are woeful - both diameter and width are inadequate. Also, the front factory calipers aren't very rigid.
If you are NOT planning on track driving, you could replace pads with aggressive semi-competition style compound and get away with improved pedal feel. Slotted rotors will help too. It may spew out dust everywhere and squeak/graunch badly, but pedal feel will improve.
For fluid, use fresh, top quality DOT 4 or DOT5.1 (not DOT5), and ensure the system is totally air-bubble-free... of course.
That'll feel better and stop well 3-4 times in a row... but anything beyond that will overheat the fronts in a big way.
Hope that helps.
Rich
Old Oct 8, 2012 | 01:45 PM
sstevojr's Avatar
This takes the cake as the lowest whp goal in the history of EvoM, ha!
Oh and re-iterate Rich above:
Boost pill
Base Map flash
Evo IX BPV
done
Old Oct 8, 2012 | 05:50 PM
Stevendjen's Avatar
i dont see a problem with wanting stock plus power. Its safer too.
Old Oct 8, 2012 | 11:32 PM
ColdNapalm's Avatar
Now the trick is to see how long that low goal stays in place :P .
Old Oct 9, 2012 | 06:34 AM
echo4papa's Avatar
The good news is that pushing yourself up to such a modest goal is both easy, and relatively cheap. Plus, if you want to push it higher down the road, you aren't reduplicating efforts.
blkdrgn09
Nov 5, 2015 07:17 AM
Canexican
Nov 9, 2013 07:46 AM
josephcastelar
Apr 9, 2013 08:36 AM
jlog1506
Dec 8, 2012 01:37 PM
dadsgts
Sep 18, 2011 09:54 PM
