Dead DRL
Old Mar 1, 2013 | 11:09 AM
jadeboy's Avatar
Dead DRL
2009 Canadian RA,
I change the DRL bulbs to LED, it was working fine, but recently both LED bulb went all dead.
It's not the bulb, I took one of the LED bulb out and change back to old bulb - nothing.
I checkd/changed the fuse (10A - #11 fuse in the engine compartment), the fuse was fine.
I checked the power for the bulb with a multi-meter, no power. Anyone has a clue as to what is wrong?
Thanks
Old Mar 1, 2013 | 12:56 PM
stfuad's Avatar
well if it's not the bulb and it's not the fuse check the relay, then the wiring.
Old Mar 1, 2013 | 01:31 PM
AusTweak's Avatar
break out the test light and start checking.
Sometimes fuses can be very deceptive and you all ways double check with a test light
Old Mar 2, 2013 | 08:58 AM
jadeboy's Avatar
Pretty sure it's not the fuse. I exchange the fuse with another 10A. The relays.. I have tested all the blue and black by exchanging them around. I have not been able to test the big grey relay because there is not a another grey relay to exchange.
Anyone know which relay is for the DRL, is it the big grey one? I going to have to figure out to test the grey relay. Can I use a test light to check it(dont have one)?
My other concern, is once this is fixed, will it happened again because I used LED bulbs.
Old Mar 3, 2013 | 11:35 AM
jadeboy's Avatar
Well, I got it fixed.
It was neither the fuse nor relay. I had to get oem stock bulbs and replaced BOTH bulbs then it started working again.
Thanks everyone for their advices.
Old Mar 5, 2013 | 09:16 AM
neogeo64's Avatar
I've been running these 18 LED DRL's for almost 8 months now, I was going through standard bulbs like every 3-6 months so that's the reason I switched. The Evo X and our cars put out 14v to the DRL so you need to find a good LED bulb that can support the voltage. The ones i linked to above are 10~30 VDC.
ithveno339jfkj4kjekjqqqq
45
Sep 29, 2025 10:10 AM
mtwallet4now
Outlander Sport
Jul 1, 2014 06:59 AM
rjoniel
Lancer Troubleshooting
Feb 13, 2014 05:20 AM
flipflop
13
Dec 19, 2012 07:07 PM
sne2040
Feb 28, 2012 04:28 AM
