Gas smell on dipstick!
Old Nov 18, 2013 | 07:32 PM
Sean Ryan's Avatar
I have a 2012 RA with a Stage 1 tune from GST and 21,000 miles on it. I noticed on my last oil change (which was changed at 3000 mile's) the oil smelled like gas pretty bad, I also noticed it on the dipstick as well. Now I have done allot of searching on this and it seams like it was only affecting people with stock tune or people that had a dealer re-tune, I did not see anyone that had a OTS tune and had this issue. I know this is an issue but, is there a solution or is this just the way it is and i just keep on as I have? Thank's for any help!
Old Nov 18, 2013 | 08:19 PM
Slee256's Avatar
Solution: Stop farting on the dipstick!
Old Nov 18, 2013 | 08:50 PM
Sean Ryan's Avatar
This will be the best reply on this thread!
Old Nov 18, 2013 | 09:54 PM
RazorLab's Avatar
Normal
Old Nov 19, 2013 | 05:36 AM
Veronica's Avatar
It can also indicate a leaking injector. The fuel system stays pressurized and a leaking injector will flow gas into the cylinder and then past the rings...
i would pull the fuel injectors and monitor for leaks...
Old Nov 19, 2013 | 05:40 AM
hotkupa's Avatar
I read that quakerstate oil have strong gasoline smell.
STi2EvoX
544
Oct 27, 2015 03:07 AM
08bluegts1
Lancer Troubleshooting
Aug 7, 2012 11:09 AM
Jasoob
Apr 19, 2012 02:22 PM
def1
13
Oct 15, 2008 06:32 PM
EVOlunchbox
18
Aug 31, 2003 12:18 AM
