SST slipping
Old Feb 12, 2014 | 07:33 PM
aguilarmp89's Avatar
SST slipping
I'm sure this may have been covered but, how do you check if the SST is slipping, all my gears shift strong and good, I down shift and its good but if the issue accures. How would I check or test it
Old Feb 14, 2014 | 06:12 AM
eh-jhey's Avatar
Not a sure fire way, but gears are possibly more likely to slip in normal mode.
Old Feb 15, 2014 | 07:55 PM
DAN123AC's Avatar
It slips even from the factory. Gears slip way less in sport mode. Also it helps if the car is warmed up and you shift at 3000 or 3600 rpm. That is always smooth for me. Anything under or over those seems to slip in my car. Kind of hard to explain what slip is in to words. It is kind of one of those thing's you will just know when it happens. Hope this helps
Old Feb 16, 2014 | 03:02 PM
kaiser1991's Avatar
^^ This.
Although if it slips to the point that you cannot pull of your driveway, that is a problem.
Old Feb 17, 2014 | 04:35 AM
DAN123AC's Avatar
Originally Posted by kaiser1991
^^ This.
Haha very true. That would make for a bad start to someone's day
Old Feb 18, 2014 | 06:24 AM
Veronica's Avatar
Keep in manual mode. Get to hwy speeds. Put it 5th gear and ~2.5K rpm. Floor it. Do the revs climb waaay faster than the speed increases? It is slipping.
Old Feb 18, 2014 | 07:56 AM
Awesome, I'll try that
Old Feb 19, 2014 | 06:27 AM
Veronica's Avatar
(unless you are waaay more modded than i think - i doubt you are slipping )
Old Feb 21, 2014 | 05:25 AM
UR 3" downpip
2.5" uicp
2.5" intercooler
DCsport tuboback exhaust
Boostpill
COBB bov
AEM intake
Base tune.
Soon to get in the next month
Evo x turbo
Catch can
E85 swap
Old Feb 21, 2014 | 08:01 AM
Veronica's Avatar
Base tune= GST Base Map w/ pill? (i hope so! :O )
If not slipping now - i t'may' with EVO X depending on the tune... AFAIK we are 'good ' up to 300ft lbs of torque...
Old Feb 21, 2014 | 01:35 PM
Corrupter's Avatar
So if there is less slip in sport mode, is it safer to drive that way on a regular basis, or does it wear harder on other parts due to the abruptness of shifting? I usually leave it in normal, thinking I will keep everything from wearing out as fast...
Old Feb 21, 2014 | 03:37 PM
DAN123AC's Avatar
Well that depends on if you have mods and a tune done. I had mine tuned in sport mode only which means I drive with it that way all the time. No mode really wears them out faster than another honestly from what I have seen and been told by the tuners I have been to.
I will say though I have been told by a few sst builders that launching is a no no for a car unless you plan on rebuilding it every year or two. More so for the SST. Launching causes the clutches to grab very hard and some slip. You can actually watch a few ralliarts on you tube launching and blowing the trans out on the track. I do not personally know anyone who has done this but just heard stories. On that same note however I have also seen people bash and treat there ralliart or MR like dirt and the thing keeps kicking. Just a luck of the draw I suppose. Driving hard from a role and or aggressive driving will wear that out a little sooner but not much more than regular driving. The sst can tolerate far more than people think or say it can.
Going back to your question though I believe you will be just fine in any mode. For me my sport mode has just always performed the best even before my tune.
Old Feb 21, 2014 | 06:43 PM
Slee256's Avatar
Sport mode all the time for me.
Old Mar 23, 2014 | 09:13 AM
tazz33's Avatar
New owner here but I think mine might be slipping just a bit as well when I'm hard into it? PO told me it needs a fluid change and it will fix it right up again though? That anywhere near correct? Also this morning (second day of owing it) it was cold and on a bit of high idle still but when I shifted into R it had a clunk is that normal or should I be checking something?
Thanx guys and gals!
Old Mar 23, 2014 | 02:27 PM
danike's Avatar
That sounds like what mine was doing exactly. I bet you need to replace your SST transmission fluid. How many miles has it been since you replaced SST fluid?
