Timing Chain and P0012?
So i started getting the P0012 code randomly and took my car in into the dealer, they checked the timing chain and said it was stretched so I had them replace it. few days later I get the triangle again. P0012 again. Only happens when I come to a stop usually at a stop light. Any one have any ideas? I've read some people state that its possible a cam sensor but no one stated that was coming on at a stop/idle. Thought I'd ask here before a 2 hour drive back to the dealer. Thanks in advance for any insight.
Car is a 2009 Ralliart. around 82000 miles.
If you get the triangle of death on the dash, don't drive the car. Or you could be up for $4K repair when a piston hit the valves. Happend to a clubcj member. Check out clubcj.net, they are Australian based and can refer you to reputable specialists.
Hey mate, did you ever figure this out? Ive replaced my timing chain and a VVT sensor and still got the warning light while stopped in traffic.
2011+ already has the upgraded timing chain so it should be fine, especially if the car is stock. They need to reset the chain sensor when replacing timing chain. A dealer or a evo specialist will have the MUT tools to do that.
Mmm, not too sure that is it to be honest. After i had my chain replaced it was a bit over a week before the warning came back. I will double check with the mechanic that replaced the chain but i remember him stating that he reset the value.
Daitonsralliart
27
Aug 17, 2019 10:19 PM
BiGnOsE
21
Feb 26, 2013 01:12 PM
