Just ordered my new wheels and tires:)
#65
Thats what I want to know as well. I can tell in teh exhaust threads around here that the RA rear subframe is different for sure and it has already been confirmed that the a arms are not the same part numbers so at this point its looking like the rear suspension mounting points may be different. The front, I've read around here, looks to be the same...
#66
Would like to buy a second Fancy set of wider rims with stickier rubber for Summer. So what is the widest rim you would use without using spacers for a daily driver for a guy who really likes his corners and what brand and size rubber to use for summer driving. I plan to use the stock rims and rubber for my Winnipeg Winter up here in Canada. Can you buy more of the valve sensors that are equiped on the stock rims or will you have an annoying light on the dash on when you go to aftermarket rims?
#68
#70
Those are 18x8 +45 with 235/40-18 tires? Why is the gap so large? Isn't the total diameter close to stock, so shouldn't the gap be about the same as stock? I'm kind of worried now because I was going to get some 18x8 +48 with 235/40-18, and I wasn't planning to lower my car yet, if ever (roads here are crappy, and I don't want to roll the fenders), but I don't want a bigger gap than stock.
mgomez
12
Apr 14, 2017 08:13 AM
pnoy_RA06
Jul 17, 2014 10:25 AM
cescpistol
Apr 4, 2014 03:30 PM
jspecgallant
Apr 4, 2014 03:24 PM
LancEric
21
Dec 16, 2010 06:45 PM
