robispec.com
Old May 22, 2009 | 07:12 AM
  #31
evocowboy's Avatar
^totally, they should be pushing the budget performance market w/ this model!
I would still go for the brakes at least.
Old May 22, 2009 | 10:05 AM
  #32
mazemonster's Avatar
Originally Posted by TheBlueBlur
Sadly, this is the truth. I don't think there is going to be a huge market for high-end ralliart parts, because if someone was going to spend several thousand on upgrading brake/suspension on a RA, they would have just bought an Evo in the first place.
you have a point. however the RA is not a bad project car for some one to start off with. he said when they where done with the RA from Robispec it was faster around the track then the lotus Elise. but it would be nice to see some less expensive stuff from them knowing your going to sacrifice some performance.
Old May 22, 2009 | 03:09 PM
  #33
just wanted to add this is a perfect thread for the suspension and brake sections
Old May 22, 2009 | 07:21 PM
  #34
LancerGTS's Avatar
I am doing just what you said wouldnt happen
With the lack of parts Ill probably be upgrading the brakes to the Evo X setup. This weekend I am having Evo 9 brake air guides fitted to the car in the meantime. In terms of suspension, WORKs is coming out with a full blown track suspension that I am waiting to get my hands on.
Old May 23, 2009 | 09:18 AM
  #35
C H's Avatar
C H
I thought the EVO didn't fit the Ralliart.
Old May 23, 2009 | 07:16 PM
  #36
LancerGTS's Avatar
If thats the case then Ill have to look elsewhere but I havent seen anything saying they dont. Is there a thread here?
Old May 23, 2009 | 11:11 PM
  #37
Ad-Rok's Avatar
You mean the wheel and tire fitment thread, formerly stickied? Granted, this is just one dude's findings, but if there is "some rubbing" without any basic suspension upgrades for track use, then I expect fenders will be in the way.
The point of wide wheels is to fit wide tires and increase tire contact patch. Nowhere in this thread does the poster indicate successfully putting a wider tire than stock Evo X (235) on the Ralliart with a properly adjusted race suspension and tracking the car. Hopefully, someone will.
-Adam
Old May 24, 2009 | 12:25 PM
  #38
LancerGTS's Avatar
Well I already have wider wheels and I will be adding the WORKs coilover system to the car in a month or two. I guess at that point I can look into it further. Thanks for pointing that out
-Adam
Old May 24, 2009 | 12:35 PM
  #39
houdini_678's Avatar
Pics would definately answer some doubts in thread...
Old May 24, 2009 | 03:15 PM
  #40
LancerGTS's Avatar
-Adam
Actually I just read over that entire topic and there is nothing about Evo brakes in that thread (unless its hidden within a large post about wheel fitment and I missed it) I already have Enkei 18x8 wheels, I was talking about the Evo brakes (rotors/calipers and any other hardware I might need to swap)
Old May 25, 2009 | 06:44 AM
  #41
Ad-Rok's Avatar
Oh, I thought you were asking about wheel and tire fitment.
I was under the impression that Evo X Brembos will not bolt on a Ralliart in place of the stock Outlander/GTS brakes and rotors with very different geometry.
-Adam
Old Aug 12, 2009 | 07:28 PM
  #42
LancerGTS's Avatar
I contacted Robispec today about the brake system. They quoted me 2100 for the system (without install costs) and then when I brought up the price listed in the first post and asked if anything had changed to bring the price up they said "yes we added brake lines", which if I am not mistaken are listed in the first post under 1950?
They wont let me come in on a weekend either anyways so it looks like Ill have to keep looking for a good upgrade.
Old Aug 25, 2009 | 10:52 PM
  #43
robi's Avatar
Easy...I said I was busy for the next few weekends.....this one Redline time attack Englistown NJ, next test and tune Willow springs next NASA nationals, ..you get the Idea. We do do installs on the weekends this just needs to be worked around the race support schedule.
This is a 4 wheel kit the brake lines alone will be around 150 as the rears are over 2 feet long...
NEW PARTS
Performance lowering springs Not too low, not too soft, not too stiff, JUST right...
Swaybars BANISH YOUR PUSH AND LEAN cornering style.
front camber kit
front castor camber plates
"SEARCH AND YOU WILL FIND"
Old Jan 5, 2010 | 10:29 PM
  #44
rAWjAW's Avatar
Update?
Has anyone heard any updates on when these are coming out?
Old Jan 5, 2010 | 10:44 PM
  #45
JohnDoe1984's Avatar
Originally Posted by 07outty
..the evo x has 18 x 8.5 wheels with 245/40 tires "stock".
these can be put on the RA with no problems ( as long as you keep stock ride height )
so our RAs' are not too bad in the "track width" area.
i just want stiiffer suspension and better brakes...
looks like the new robi stuff will meet my needs.
You can't put stock evo x wheels and tires on a ralliart without rubbing. I have seen one guy on the forums put a set of x wheels on his RA but he went down to 225/40 tires so they didn't rub.
