Ralliart Big Brake Upgrade
Old Jun 6, 2012, 03:44 PM
  #796
sstevojr's Avatar
Here you go:
https://www.evolutionm.net/forums/09...35-w-265s.html
sstevojr is offline
Old Jun 6, 2012, 05:21 PM
  #797
import_racing's Avatar
Originally Posted by sstevojr
Looks good! Looks like im going to go get my calipers grind flat before I get them powder coated.
Thanks for the heads up!
import_racing is offline
Old Jun 6, 2012, 05:41 PM
  #798
Eric, did u also had to grind off the calipers as well? Or you just left it how it was?
Old Jun 6, 2012, 06:09 PM
  #799
NFSLancerRA's Avatar
I had to grind them. I forgot that you bought your parts from a 3rd party and not Kore3. Tobin has a good deal on grinding. He does a good job, too. But yeah, 2mm should do it.
NFSLancerRA is offline
Old Jun 7, 2012, 02:01 PM
  #800
Thanks
Old Jun 12, 2012, 12:12 PM
  #801
Speed Devil's Avatar
Just installed Evo X MR brembos on my Ralliart
https://www.evolutionm.net/forums/09...-ralliart.html
Speed Devil is offline
Old Jun 14, 2012, 02:14 AM
  #802
spekil's Avatar
Eric, do u have any available bracket for front basic C5 set up? Only the brackets.
spekil is offline
Old Jun 14, 2012, 05:08 AM
  #803
PM'ed
This is the last set from the first round of production. The next round of brackets will be ready in a week or so.
Old Jun 14, 2012, 05:12 AM
  #804
Since you posted this in my thread, I will give you my honest opinion of that work. I never advocate altering the body of aluminum calipers. The best case scenario is that nothing happens. However, if you go too far or don't lubricate the press properly, you WILL destroy the calipers. If people buy this kit, do not attempt to make the required modifications yourself. I knew that that was a possibility, and I ditched the project for that reason. It is just my personal philosophy. That is a really "ghetto" way of making them fit. I am concerned about that setup.
Old Jun 14, 2012, 09:16 AM
  #805
sstevojr's Avatar
Agreed, that is why I went the Z06 route
Speaking of which, any news on the rear brackets for the Z06 4 piston?
sstevojr is offline
Old Jun 14, 2012, 02:28 PM
  #806
Plus 2 =D
Updates on z06 rears?
Old Jun 15, 2012, 11:04 PM
  #807
spekil's Avatar
Now I got confuse abit. Instead of going to kore3, I'll be using the stock corvette C5 front calipers with my stock 18" rims. I won't need to grind anything, is that correct?
spekil is offline
Old Jun 16, 2012, 01:30 AM
  #808
Yes that is correct with the C5 standard brake kit, you just need the bracket from Eric and your set to go. It would fit with our stocks wheels no problem. =D
Old Jun 16, 2012, 05:57 AM
  #809
Plus 2 =D
Working on it. My metal shop is still tied up with more basic brackets. That should be about a week or so. Over the next week, I will be developing the rear, as a consequence, so that production can begin when the jet is free. We are playing water jet chess, I swear.
Old Jun 26, 2012, 06:58 PM
  #810
BigDsRalli's Avatar
Looking forward to getting the 6 piston calipers on my car! PM sent for payment instructions. Thanks Eric!!
BigDsRalli is offline
Quick Reply: Ralliart Big Brake Upgrade
