Factory alignment specs
Old Apr 26, 2011 | 08:36 PM
BravoZero's Avatar
Does anyone have, can get, or point me to where I can find the factory alignment specs for the Ralliart? I know my car is off and Im having a custom shop install and setup my coilovers Friday and they want me to provide them with what alignment specs Id like to have. I need the factory specs so I can make changes if needed.
Old Apr 26, 2011 | 09:40 PM
Livefast.eu's Avatar
Looking for these too
Old Apr 27, 2011 | 12:38 PM
stfuad's Avatar
search for an older post of mine asking the same question.
Old Apr 29, 2011 | 11:54 AM
BravoZero's Avatar
Found that thread, thank you.
Got the coilovers installed today, but can't pick it up until tomorrow for certain reasons. They set the toe angle all around to zero and set both of the front wheels at -1.5 camber. They did the best they could on the rears to match it, but could only get -1.6 on the left and -1.4 on the right. Is that going to make a huge difference in handling and tire wear?
Old Apr 29, 2011 | 12:14 PM
toredefine's Avatar
Did you get the rear camber kit from Whiteline, or something similar?
Old Apr 29, 2011 | 12:18 PM
BravoZero's Avatar
No additional camber kit. I had the BC Racing BR series coilovers installed, so whatever he did to make adjust it I guess. He mentioned that the BR's had camber plates.
Old Apr 29, 2011 | 12:25 PM
toredefine's Avatar
I'm really glad this thread popped up. I was wondering what the stock specs were for our Ralliart's. I'm installing a lot of parts this weekend, and one of them is the BC Racing BR coilovers, too. I have an appointment to get my alignment done next week.
The camber plates that come standard on the BR series are only for the fronts. You've got to pay extra (not much) for camber adjustments for the rear. OR, you'd have to go the Whiteline Rear Camber Kit route (or similar product), which I did. That's why they can't apply more negative camber to the rear.
Old Apr 29, 2011 | 12:26 PM
BravoZero's Avatar
EDIT: Toredefine beat me to it about the front camber plates only.
My question is simply this... with the rear left set to -1.6 and the rear right set to -1.4, is it going to make a huge difference for daily driving as far as handling and tire wear?
Old Dec 17, 2012 | 07:28 AM
D-Man's Avatar
Where did u find the specs?
Old Dec 18, 2012 | 04:39 PM
neogeo64's Avatar
Here was my 2011 fresh off the boat "Before"for reference.
You can see the 2 numbers to the left and right that mitsubishi considers Factory Specs.
Old Jan 2, 2013 | 06:49 AM
Onyx1607's Avatar
Front axle
Individual toe: +0.2mm +/-0.3mm
Camber: -00°05' +/-00°30'
Caster: +02°40' +/-00°30'
Kingpin Inclination (KPI): +13°30' +/-01°30'
Rear axle
Individual toe: +0.8mm +/-0.6mm
Camber: -00°55' +/-00°30'
buckmarley
Jun 14, 2013 03:28 PM
taylorgang
12
Feb 18, 2012 11:59 AM
shinobee1
May 28, 2008 08:48 PM
iodine23
Apr 12, 2004 08:55 PM
