Racing Line Rear Endlink Install and Review
#46
Did you try contacting them? I know in the past they make their products in batches; there have been times where someone had to wait a month to order (due to backlog).
I'd contact them, and then PayPal. They should have sent you a confirmation email, even thru PP for tracking.
#50
Update:
It's finally happened......I've blown out my front end links (despite using full soft to try and prevent this from happening).
Unfortunately no one seems to make a beefy front endlink; so I've had to order a stock type one made of (what I hope is) a slightly stronger material:
http://www.ebay.com/itm/320893816378...#ht_1804wt_952
I'll let you know when it arrives, but to be honest these use the same type ball joint rather than a spherical joint, so I don't expect them to last
#52
The front sway bar is 26mm (Whiteline) and the rear is 24mm (Whiteline), so the lateral force is considerably more than what the stock sway bar were. Eventually the spherical joints break inside the dust boot thingy (no longer, just free floating); so when I go over a bump it 'crunches' from sliding past each other (metal on metal grinding), rather than rotating.
Speaking of which, I need to re-tighten the rear endlinks, after a hand full of track days they bolts are starting to loosen up (backing out slightly). I still LOVE the Racing Line Rear Endlinks (Evo X Front's for those who may have forgotten), they have been superb for the amount of thrashing they have gone through. I just wish Racing Line would take the same rod end joints and make a longer shaft, so we can have a set for the front. A bigger sway bar in the front allows for a whole lot more turn in before the 'limits' are reached (when understeer occurs), allowing go-kart like attributes
#53
The front sway bar is 26mm (Whiteline) and the rear is 24mm (Whiteline), so the lateral force is considerably more than what the stock sway bar were. Eventually the ball joints break inside the dust boot thingy (no longer, just free floating); so when I go over a bump it 'crunches' from sliding past each other (metal on metal grinding), rather than rotating.
Speaking of which, I need to re-tighten the rear endlinks, after a hand full of track days they bolts are starting to loosen up (backing out slightly). I still LOVE the Racing Line Rear Endlinks (Evo X Front's for those who may have forgotten), they have been superb for the amount of thrashing they have gone through. I just wish Racing Line would take the same spherical joints and make a longer shaft, so we can have a set for the front. A bigger sway bar in the front allows for a whole lot more turn in before the 'limits' are reached (when understeer occurs), allowing go-kart like attributes
Whiteline also makes front endlinks for our cars. I don't know if they are any good but hey, they are made from whiteline so i assume that they should be good. =D
http://www.lancershop.com/customer/p...cat=188&page=1
#54
That website is wrong, those are about 12 inches too short.
Whiteline does list endlinks for our car, but they aren't "made" for our car; they are generic spherical joint endlinks with a shaft that need to be cut to size and screwed together.
I hate that website(Lancershop), they always miss-post info, here is what that PN is from Whiteline:
http://www.energysuspensionparts.com...asp?prod=KLC39
#56
I 'think' I might have figured out a way to get some front endlinks made, same type of rod end joint and all
Should know by the end of the weekend yeah or nay.
#58
My replacements just got delivered last night (I was expecting them on Saturday, but that was a bit too optimistic for Customs). Sorry, I need to swap them out so I can get my stock ones for specs/measurements.
#60
If anyone wants to post up the dimensions for the front or rear end-links for the ralliart then I can put together a kit for adjustable endlinks with off the shelf parts.
I will accomplish this by using grade 8 bolts and better spherical bearings. I will need the length of the end link that needs to be replaced. I am not selling these just showing you how to make these yourself.
