Ralliart Big Brake Kit (Take 2)
Old May 6, 2013, 08:19 PM
  #166
NFSLancerRA's Avatar
Originally Posted by robyn402
is anything in this kit going to be difficult to come by if when it comes time to replace a component?
Nope. Everything is pretty straightforward.
Old May 7, 2013, 05:56 AM
  #167
billyboy1's Avatar
nice work mate - that kit is shaping up to be awesome. going to be better buying this than replacement rotors and pads for the mrt kit!!
Old May 10, 2013, 05:40 AM
  #168
Momengah's Avatar
getting very excited here awesome work mate!
Old May 11, 2013, 09:21 AM
  #169
badchad23's Avatar
Will we get an option to pick different colors of calipers, or will they just be one color available?
Old May 12, 2013, 04:46 PM
  #170
SSP Jason's Avatar
There will be several colors available but we're going to have (2) standards.
Old May 12, 2013, 06:27 PM
  #171
Fuego's Avatar
Nice, when will the full release be? :-)
Old May 13, 2013, 11:43 AM
  #172
badchad23's Avatar
black and red?
Old May 13, 2013, 11:56 PM
  #173
parralegend's Avatar
If this is going to end up a affordable brembo solution then I'm all for the kit
Old May 14, 2013, 12:05 PM
  #174
Full Kit:
That is complete and ready to ship. Jason@SSP will be getting the first one, as he commissioned the project. The second that you see pictures from him show up in this thread, we will start taking orders.
The kit comes with Powerslot front rotors (hub-centric, common part number), custom Brembo calipers (these bolt right on, no brackets or grinding), APE SS lines (custom fit), Brembo pads (this is a part that Brembo already makes), mounting bolts, shims (Brembo direct), and caliper pins/pad retainers. It fits like a glove. There is no pad overlap. The swept area has been measured down to the nearest 0.5 MM.
Again, this kit requires NO BRACKETS. This was designed from the get-go to bolt onto your car the way that it would from the factory. The hydraulic system was taken into account, and this front is perfectly matched to your OEM rear. It took years to research and develop this system, and I know that you guys will enjoy it. I almost wish that I still had an RA to give this bad-boy a try. Again, this was all for you guys. I really hope you like it!
Old May 14, 2013, 12:09 PM
  #175
Anything you want, we can do. If you want CF covered calipers, we can do that. If you want different rotors, we can do that.
Old May 14, 2013, 02:48 PM
  #176
import_racing's Avatar
Congratulation to you Eric for finally completing this kit and releasing it to the Ralliart Community!!
Old May 14, 2013, 02:55 PM
  #177
BravO)))'s Avatar
Are those both front and back or just front?
Old May 14, 2013, 03:07 PM
  #178
Just front.
Old May 14, 2013, 04:57 PM
  #179
Fuego's Avatar
Can u guys make a mini kit for the rear front kit? I know we have to use the OEM calipers but a kit with everything else to match the front :-). Rotors, brake pads, lines :-)
Old May 14, 2013, 05:39 PM
  #180
We can do better than that.
Quick Reply: Ralliart Big Brake Kit (Take 2)
