Ralliart + EcuFlash =
Old Apr 4, 2009 | 11:41 PM
  #31
JONralli09's Avatar
whats a "gm"?
Old Apr 21, 2009 | 05:24 PM
  #32
GST Motorsports's Avatar
Originally Posted by JONralli09
whats a "gm"?
It is a upgraded "aftermarket" 3 port boost control solenoid that provides greater control and 'resolution' than the 2 port OEM solenoid.
We are hoping to have some data from a 3 port solenoid upgraded Evo 10 soon that will obviously translate to a Ralliart as well.
Old Apr 21, 2009 | 06:30 PM
  #33
evil03's Avatar
Originally Posted by GST Motorsports
Remapping only. This includes boost maps, timing, fuel, mivec, etc.
Boost up top held was 12.5 psi, up from 8.5 psi stock. 100% stock boost system, no pill upgrade. That comes later.
More details later.
so our stock boost is 8.5 psi only?
info from mitsu website
Engine Type: 2.0L MIVEC Turbo I4
Engine Code: 4B11T
Valve Train: DOHC, 16-valve, Mitsubishi Innovative Valve-timing Electronic Control system (MIVEC)
Displacement: 122/1998
Bore x Stroke: 3.4 x 3.4/86.0 x 86.0
Compression Ratio: 9:1
Horsepower @ RPM: 237 @ 6000
Torque @ RPM: 253 lb.-ft @ 2500 ~ 4750
Engine Block: Aluminum
Cylinder Heads: Aluminum
Redline RPM: 6500
Fuel System: MPI
Emissions: Tier 2 bin 5 LEV II-LEV
Recommended Fuel: Premium Unleaded, 91 octane min.
Radiator Core size: 700x409x27
Engine Oil Type: 5W-30
Engine Oil Capacity: 5.9/5.6
Turbo Boost(Max PSI): 17.9
Old Apr 21, 2009 | 06:42 PM
  #34
Metall1ca's Avatar
interesting, i've read fairly consistently that it peaks at around 18 then settles to 13
Old Apr 21, 2009 | 10:47 PM
  #35
No not peak, that is what it tapers to.
Old Apr 21, 2009 | 11:05 PM
  #36
Metall1ca's Avatar
I stand corrected. So after boost pill what do we taper off to?
Old Apr 21, 2009 | 11:20 PM
  #37
All that info and more here:
https://www.evolutionm.net/forums/20...ns-o-data.html
Old Apr 21, 2009 | 11:24 PM
  #38
Metall1ca's Avatar
Lol my bad, epic fail. Thanks though, that is definitely worth the 18 dollars.
Old Sep 1, 2009 | 01:22 AM
  #39
RotorGlow's Avatar
oops
Old Sep 6, 2009 | 12:35 PM
  #40
Hey all,
We are now officially offering the GST BaseFlash and for a very affordable price. Please PM me for info if interested
A bit "detuned" version of our old BaseFlash is now available for free as a BaseMap, more details here:
https://www.evolutionm.net/forums/09...t-basemap.html
razorlab
548
Sep 14, 2019 07:23 AM
GST Motorsports
32
Dec 24, 2017 10:16 PM
GST Motorsports
Feb 19, 2010 01:31 AM
razorlab
Evo X Dyno Results
146
Apr 30, 2009 03:33 PM
razorlab
Evo X Dyno Results
33
Dec 27, 2008 12:12 AM
