5w-20 vs. -30
5w-20 vs. -30
just pick up some mobil1 5w-20 (live in pa) and realized everyone seems to be putting -30 weight in their RAs...u guys think i should go swap it out or is there not any compelling reason to use -30 over -20?
I noticed that when I went to the dealership for an oil change a couple back, that they put 5w-20 in. I thought the RA manual recommended that we use 5w-30 synthetic? I'll take a look in a little bit.
Found the thread, this should help
Oil for the ra
From the thread:
Oil for the ra
From the thread:
From my understanding, many manufacturers in the U.S. have been using 5w-20 to help improve emissions, at the expense of engine life some say. There is a very good chance that the R/A manual in Europe, Japan, and Australia recommends 5w-30, and that's probably your best bet. There are plenty of posts on this forum regarding oil, so you should probably just do a search. Simply put, many people would argue that there is much better synthetic oil out there than Mobil1 (which isn't truly synthetic anyways).
ive used 5w-30 in my 09 gts and 5w-20. id say to use 5w30 in the ralliart , you dont want to put the same oil in your engine as people with 08 and 09 lancers do. at least i wouldnt think so.
20 weight oil is certainly thinner than 30 weight. 20 weight will improve gas mileage as there is slightly less viscosity (and therefore friction) on moving parts. But since it's thinner it will shear easier, and when that happens, you will most likely get metal to metal contact (You NEVER want that). You also don't want to go too high (like say a 50 weight maybe) because the pump and the oil gallies may have not been designed to flow enough oil at that weight, and therefore, you would starve parts of oil, and again get metal to metal contact. During the summer, you can probably use 10W-30, but if you're not a cheapskate (and care about what's best for your motor), you should use high quality 0W-30 synthetics like RedLine, AmsOil, Royal Purple, etc.
mitsucars.com
The specifications page for the Lancer says 5-W30 for the Ralliart and 5-W20 for the lesser models.
N1Mr0D, you can certainly use whatever oil you like in your own car, but you won't ever find me using a 20-weight in any of mine.
Ok I didn't say I can't find that viscosity oil, I said I can't find amsoil in my area. And I have talked to some shops, checked on amsoil website, talked to distributors on this website and got a quote not only very expensive but I would have to pay shipping which is also a lot! and no "pep boys" or discount or autozone have it. Don't tell me I haven't tried hard enough! If that oil is so good which I don't doubt it is, they need to market it better and get more places selling it!!
MarkChamorro
May 9, 2012 08:14 AM
