Tactrix and ecu flash review and how to
here it is... comes with everything you need!!!
http://www.tactrix.com/product_info....products_id=40
There are ways to increase boost without the need for a pill.
Here we go. went on a dyno this morning and my stock run was 216whp and after i uploaded TTP map i gained 43 WHP ......end result 259WHP/258 lbs-ft TRQ very impressive... I had few things working againts me. 1 they had only one fan blowing on my engine. 2 it was already 87F at 9 am. i am positive i would have made more...
mods: k and N drop in filter, UR axle back, UR upper intercooler pipe, evo X BOV
Stock and best run with TTP map
Best run and 3 run, both TTP map.
VIDEO!!!! CLICK ---->>>>>
<<<<---CLICK
Driveability improvements
Scott/Jake do you want to talk to drive-ability improvements. I personally feel the stock Ralliart goes very flat on the top end and feels like you are out of pull at about 5000 rpm and that you are almost better of short shifting.
From the dyno it looks like the power does not drop off as much after the TTP map ?
Does the TTP include any changes to the rev limit ?
Does the TTP boost solution allow as much boost as a boost pill solution ? What does the boost peak and what does it settle to ?
I notice from the mod list there is a drop in K&N and an axle back exhaust. Just condering how much if any effect those items have on the peak power ?
Yes, just let us know what modifications are done as well as the octane and altitude and we can semi custom tailor a map for each individual Ralliart.
