Tactrix and ecu flash review and how to
Old Aug 1, 2009 | 07:33 PM
Jake26's Avatar
So I was really nervous getting into tuning. But since i got my ralliart i went ahead and tried it.. It was very easy using ecu flash with the Tactrix cable.
VIDEO CLICK------>>> http://www.youtube.com/watch?v=ZJmLhGL4t9Q <<<<------CLICK
1. For ECU FLASH software and cable go to www.tactrix.com and the correct cable to get for your 09 ralliart is the open port 2.0 that costs $169.00 ( you can find it under evo x )
2. After you turn on your laptop ( widows xp-vista-MAC) connect your cable to the ECU port.. Then let window find drivers for open port 2.0.
-------Windows xp/vista x86 x64 ecu flash http://openecu.org/downloads/ecuflash_1422595_win.exe
-------MAC OSX 10.4-10.5 x86 x64 ecu flash http://openecu.org/downloads/ecuflash_138_osx.dmg
3. launch ECU flash, after all drivers are loaded and ECU flash is open.. select 2006+ Mitsubishi CAN, then Go ahead and click read from ECU. **make sure you have your ignition on at this time. ( not cranked )
4. You will notice your ECU going crazy.. It will display warnings, that everything is messed up, your fans may kick in.. No worries, ECU is just being read and reset.
After the scanning bar reaches 100% you can turn the ignition back to OFF position...
Then you will notice vehicle description, fuel maps, turbo boots etc etc..
AT THIS TIME SAVE YOUR ROM AS 09ralliartSTOCK
Then you can send this ROM to scott at TTP ( email flash $399.00 http://ttp-engineering.com/catalog/p...roducts_id=422) and he will tweak it for you, and you should put down on a dyno around 290WHP with your ralliart...
***You may have a check engine light on after the ECU scan!! NO WORRIES ECU FLASH SOFTWARE can delete them for you.. There is an option under ECU in the software itself. So no more going to auto-zone or advanced auto parts to get your ecu checked!!
I did this the first time and everything worked like a charm... Hope this helps some of you..
***after you get the tweaked ROM back from TTP, i suggest you do test write to ecu first, then write to ecu..
Old Aug 1, 2009 | 10:48 PM
TTP Engineering's Avatar
Excellent write up. Will have your map to you shortly!
Old Aug 2, 2009 | 01:51 AM
bmanuhutu's Avatar
not saying that anything is impossible, but saying 290 whp on your stock RA with just a flash seems to be a tad bit over exaggerating
Old Aug 2, 2009 | 06:38 AM
Jake26's Avatar
i know but guy can dream cant he hahahha
Old Aug 2, 2009 | 06:41 AM
Jake26's Avatar
thanks scott i cant wait till tuesday i am loading it up today!! dyno day is tuesday... i will have my stock map and yours so when i get to the dyno i will load the stock one back on and do a base run then i will load yours up and see a comparison. But right now i cant wait till that day so i am gonna go upload it now and see if i can smoke a evo x hahahhaha
Old Aug 2, 2009 | 08:02 AM
jazket's Avatar
hahaha lol
nice write up! dyno ur car once u get ur flash to see where youre at
Old Aug 2, 2009 | 08:49 AM
Jake26's Avatar
Originally Posted by jazket
hahaha lol
i have loaded the ttp map already, boy this flimsy ralliart became a beast.. it pulls so much harder even at higher RPMs. I have my stock ROM saved i will load it back once on a dyno then do TTP rom to see the numbers over stock
Old Aug 2, 2009 | 10:32 AM
Gibby860's Avatar
Can't wait to see the numbers? Any ideas, did TTP indicate what your flash should be running at for HP/ TQ?
Old Aug 2, 2009 | 10:58 AM
Jake26's Avatar
i should be around 30-40whp over stock but we will see on tuesday when i do dyno.
Old Aug 2, 2009 | 01:56 PM
596736's Avatar
Good write up. I thought ttp charged a lot less for the email flashes?
Old Aug 2, 2009 | 04:02 PM
boondoc's Avatar
Nice write up. I'm actually saving up to do this myself aswell.
Old Aug 2, 2009 | 04:34 PM
higgs's Avatar
looking forward to see your comparison. So the tunes by TTP are done pretty custom? I'm really interested but my car is stock right now. If i later add mods is there any break in price for a 'reflash' email tune?
Old Aug 2, 2009 | 04:52 PM
We have used tons of data from in house custom dynotuning to develop strong, powerful and safe mapping for many different modification levels.
Old Aug 2, 2009 | 04:57 PM
redleg225's Avatar
What dyno are you going to? EPIC Motorsports?
Old Aug 2, 2009 | 05:16 PM
Jake26's Avatar
yeah i have a appointment set at epic motorsports on tuesday at 9:30am all i am doing is 3 dyno pulls..
you gonna come out?
