Perrin EBCS
Old Sep 23, 2009 | 09:47 AM
secondchace's Avatar
again 12.2 at 3000 rpm isnt a bad thing, 5-7000 is where you need to worry.
Old Sep 23, 2009 | 10:32 AM
Seawolf's Avatar
base latency. But you could listen to secondchace and just add in more timing without more fuel to see what you can pull of. Once you start seeing knock, back off timing or add more fuel. Go slowly though.
Old Sep 23, 2009 | 05:40 PM
Piper747's Avatar
I hear what you're saying. After posting the log in the first post I did more logging and the afr was always even leaner than that log shows. I was frequently seing afr in the high 12s at peak boost. It runs lean only once the turbo really starts to spool then richens up. Even though my posted log may be a safe afr I was bothered by the fact that I could not alter it much with the fuel map in that area. I like to experiment and will see what happens with the latency. Here is a log that represents the afr I was often seeing.
Old Sep 23, 2009 | 07:04 PM
Piper747's Avatar
Well I tried to add a bit of latency and the car would not start. Flooded badly. I tried 2ms then 0.6 then 0.2 starting it each time after it flooded and still would not start. No more of that!!! Not sure what to try next.
Old Sep 24, 2009 | 08:30 AM
Bom's Evo's Avatar
Depending on how much load the engine is in, it could be... These cars are meant for boost though so they can take a lot!
It's just a nice lean-spool for the turbo, but I don't know how much you have to lean the engine to spool this baby turbo.
Old Sep 24, 2009 | 08:41 AM
Seawolf's Avatar
Well, it isn't milliseconds. It is a multiplier FOR latency, and it seems to be per cylinder...you can read more about it here:
https://www.evolutionm.net/forums/ec...ency-base.html
or
https://www.evolutionm.net/forums/ec...lp-needed.html
The next step would be to change the injector scaling size. If you tell the ECU that your injectors are smaller than they really are, it will richen-up the mixture, because it will think it has to pump in more fuel to be on target.
I would suggest, though, that you read all the info available in the EvoX forum before you go much farther. I would hate to see you throw a rod or something like that.
Start here and read all pages:
https://www.evolutionm.net/forums/ev...10-thread.html
Old Sep 24, 2009 | 09:27 AM
this pertains to any load. 12 psi, 24 psi, doesnt matter. Keep in mind hes on the stock turbo.
12.2 afr at 3000 that richens into the 11's at 6800 rpm is a perfect mixture for ultimate power on the car. Most try to keep it richer for safety sake, but there is no negative to this.
Old Sep 24, 2009 | 05:06 PM
Piper747's Avatar
or
Thanks man. I appreciate the pointers. I will give the fuel map one more try before attempting anything further. It may be that it just takes an even lower number yet to change the afr. It does not seem to be a linear relationship between the map afr and the real afr. I guess I obviously need to take load into account. That makes sense. Thanks for the links...lots of good info.
Careyalfie
Mar 20, 2017 10:06 PM
wrinkly
Mar 6, 2017 02:38 AM
northevo
Dec 14, 2011 08:18 AM
PERRIN_JOHN
Mar 13, 2009 11:38 AM
Chabada15
Jun 9, 2008 04:49 PM
