Hks ssqv
Old Sep 30, 2009 | 05:24 PM
Jyrk's Avatar
if you have all the parts and want to use it then do so.
If it causes problems then go back to stock?
i dont see the point of this on going thread............................................ .................................................. ............................................
Old Sep 30, 2009 | 06:24 PM
jcm308's Avatar
The point of this thread is to get feedback from people that have already used these parts on their RA or EVO X.
As I mentioned in my first post, I have heard that the SSQV can potentially cause issues with the TC SST but I have not been able to confirm:
1- Is this true!!!!!
2- Was it setup as recirc or vent to atmo!!!!!
If you can answer either of these 2 questions then please feel free to do so.
Old Sep 30, 2009 | 06:25 PM
jcm308's Avatar
Originally Posted by evil03
which version do you have?? ver. 1, 2, or 3??
I have version 2
Old Sep 30, 2009 | 09:00 PM
ambystom01's Avatar
Originally Posted by jcm308
The SSQV I have does self adjust so turbo surge will not be a problem.
So by the sounds of it only a few people on here have actually ever used one of these and not had any problems when doing so, is this correct????
I'm not interested in what other types of BOV and DV are like as I do not already have them but I do already have my HKS one so any more info on this would be appreciated.
As with most stock parts of this nature the standard BPV appears to me to be pretty crappy. In my previous expirience with different brands of turbo cars unless you buy a very high end car the plastic BPV leak. This would probably be the reason the EVO MR's come with metal BPV's instead as they are Mitsubishi's top model.
The stock plastic piece does not appear to leak. What proof do you have that it is leaking? From what I've seen, most people are still using the stock BPV even when they mod.
Old Sep 30, 2009 | 09:22 PM
jcm308's Avatar
I don't have any proof that the standard BPV leaks in the RA (nor did I say it did). What I stated was with my previous experience the standard plastic BPV's are cheap and do leak.
What I do wonder is why the RA's boost tapers off as soon as it hits peak boost? Could this be because of the standard BPV not holding the pressure (seems likely)?
Old Sep 30, 2009 | 09:43 PM
ambystom01's Avatar
No, if your BPV was leaking, you wouldn't hit peak boost, period. What you're experiencing is because of the small stock turbo.
Old Sep 30, 2009 | 09:49 PM
jcm308's Avatar
Are you sure about that amby?????
Usually the turbo's are set well within their boost limit and will hold boost through the majority of the rev range before tapering off at top end revs. From the maps I've seen on the RA, it hits peak boost around 3k but then almost immediately starts to taper off all the way to redline.
Old Sep 30, 2009 | 10:01 PM
ambystom01's Avatar
It isn't a matter of the turbo being within it's optimal boost range, it's simply a factor of its size. A small turbo will always behave like a small turbo, meaning fast spool but mediocre top end performance. The WRX and STI behave the same way because they also have relatively small turbos.
Old Sep 30, 2009 | 10:03 PM
jcm308's Avatar
I know and agree with this but if you look at the boost curve on a stock RA it doesn't even hold peak boost for 1000RPM. I think there's more going on there than just a small turbo. The standard turbo should hold boost for at least 2500 - 3000 RPM before tapering off.
Old Oct 1, 2009 | 08:29 AM
ambystom01's Avatar
No, it is just the size of the turbo, nothing more. If it was the BPV, you wouldn't be able to hit 18 PSI at all. Look around at other dynos, when tuned, the car holds boost fine.
Old Oct 1, 2009 | 09:50 AM
velocityhead's Avatar
I agree, it's mostly the small turbo and conservative tune. Look at some dyno charts from vendors with reflashes here....the boost curve holds max boost for about 1500-2000 rpm.
Edit: let me take that back, I can't seem to find the dyno charts I was looking at. I might have been thinking about the torque curve instead...
Old Oct 1, 2009 | 10:07 AM
ambystom01's Avatar
Most boost curves show a spike and then they drop off. With a tune, the drop off is slower. All small turboed cars operate like this, it's just what they do.
Old Oct 1, 2009 | 10:50 AM
GST Motorsports's Avatar
The turbo tapers by design on a stock 09 Ralliart. The boost control has the boost curve programmed in the boost control tables. The boost can be tuned to not drop as much but the turbo itself is pretty small and will taper no matter what at some point
Stock duty cycle tables, notice drop in duty cycle by design, this and the OEM restrictor pill is a "factory tuned" system for the desired boost curve.
Boost curves, Stock vs Tuned vs boost pill tuned:
The plastic BOV on the 09 RA is the same plastic bov that was found on the 03-05 Evo 8's. It will start to leak substantially around 23 psi peak and about 21-22 psi up top. It actually *slightly* leaks with anything over 20psi.
Old Oct 1, 2009 | 02:48 PM
jcm308's Avatar
Thanks for all the info guys.
It's good to know what the limitations of the standard BPV are. It surprises me a little to hear that they're good to at least 20psi.
By the looks of the graph ^^ I need to get a retune and boost pill upgrade to go with the BPV replacement
Back to my original questions, Can anyone give me feedback (good or bad) relating to a SSQV in a 09+ RA or EVO X????????
PatricksEvilEvo
16
Feb 3, 2013 05:45 PM
vics(evo8)
Evo X How Tos / Installations
10
Apr 4, 2012 06:07 AM
Evo8*
Nov 20, 2011 09:09 PM
matizzay
Nov 3, 2011 07:51 PM
AJR-Coco
Dec 11, 2009 12:12 AM
